    Bltouch Probing Question
    • 57buickundefined
      57buick
      So I setup my BLtouch per these instructions at this link. And it works fine for the most part. But I noticed everytime it probes when it lifts up it deploys and retracts an extra time as its lifting. So its moving the probe double for every time it probes. Why is it doing that.? Does it have anything to do with my deploy and retract macros I created?
      https://betrue3d.dk/bltouch-on-duet-wifi-configuratio-and-usage/
      ; bed.g
      ; generated by RepRapFirmware Configuration Tool v2 on Fri Jun 14 2019 19:58:14 GMT-0700 (Pacific Daylight Time)
      M98 Pdeployprobe.g ; deploy mechanical Z probe
      G28 ; home all axes
      G29 ; probe the bed and enable compensation
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      M208 X0 Y0 Z0 S1 ; sets the minimum values for all axes
      M208 X300 Y300 Z400 S0 ; sets the maximum values for all axes
      M574 X1 Y1 S1 ; X home to min. Y home to min. Normally Closed limit switches.
      M574 Z1 S2 ; Define Z to use Probe. Home to Min
      M558 P9 H7 F200 T4000 X0 Y0 Z1 ; Set Z probe type/mode 9. H=Dive Height. F=Speed the bed moves
      G31 P25 X-38 Y-8 Z1.58 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
      M557 X20:280 Y20:280 S20 ; Define mesh grid
      M569 P0 S0 ; Drive 0 goes backwards
      M350 X16 Y16 Z16 E32 I1 ; Configure microstepping with interpolation
      M92 X80 Y80 Z400 E202.2 ; Set steps per mm
      M566 X1200 Y1200 Z24 E300 ; Set maximum instantaneous speed changes (mm/min)
      M203 X30000 Y30000 Z600 E5000 ; Set maximum speeds (mm/min)
      M201 X500 Y500 Z100 E5000 ; Set accelerations (mm/s^2)
      M906 X800 Y800 Z700 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M143 S265 ; Set maximum heater temperature to 265C
      ; BLTouch - Heaters
      M307 H7 A-1 C-1 D-1 ; Disable the 7th Heater to free up PWM channel 5 on the Duex board
      M563 P0 D0 H1 ; Define tool 0
      M550 PCR10SDuet ; Set machine name
      M552 S1 ; Enable network
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M106 P0 S1 I0 F500 H1 T50 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P1 S0 I0 F30 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off - have 2 Blowers parallel
      M106 P2 S0.5 I0 F30 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off - have 2 Case Fans parallel
      ; Custom settings
      M912 P0 S-13 ; calibrate MCU Temp
      M501 ; with PID Tune data
      T0 ; Select first tool
      ; homeall.g
      ; called to home all axes
      ; generated by RepRapFirmware Configuration Tool on Sat Oct 28 2017 00:02:03 GMT+0200 (Mitteleuropäische Sommerzeit)
      ; Relative positioning
      G91
      ; Course home X and Y
      G1 X-305 Y-305 F3600 S1
      ; Fine home X and Y
      G1 X-305 Y-305 F3000 S1
      ; Move away from the endstops
      G1 X150 Y150 F3000
      G30 ; Do a single probe
      ; Homez.g
      G1 X150 Y150 F6000
      G30 ; Do a single probe to home our Z axis
      G91
      G1 Z20 F3000 ; Rapidly move the Z axis to Z=20
        From your other thread, I understand this this is now solved.
        • 57buickundefined
          57buick
          yep all solved after updating, just homed Z perfectly then ran a bed mesh and just one probe each time like its supposed too, thanks again
