    external trigger switched by Faults
    My Duet controlled machine
    • CR3Dundefined
      CR3D
      Hi everybody,
      for my printers i want to install some visual components (Error lamps and something else) which are switched on by Heater Faults or other Faults...
      Is it possible to use a heater fault to switch an external trigger ?
      Which Faults are also possible to detect with the duet?
      Thank you a lot! 🙂
      Regards Christian
      Christian from CR-3D
      Homepage:
      www.cr-3d.de
      Facebook:
      https://www.facebook.com/cr3d.official
      Our Discord Server
      https://discord.gg/SxRaPNuRdA
      Thingiverse Profile:
      https://www.thingiverse.com/cr-3d_official/about
        That's not possible at present, but should become possible when I finish implementing conditional GCode in RRF 3.
        • CR3Dundefined
          CR3D
          Ok thank you! 🙂
          Homepage:
          www.cr-3d.de
          Facebook:
          Our Discord Server
          • hayseed_byteundefined
            hayseed_byte
            That would be cool. Maybe a buzzer....
            https://wildbot.me/wildbot
            Gcode Definitions for VSCode extension: https://github.com/hayseedbyte/rrf-gcode-definitions
