    M581 Filament Sensor?
    • techundefined
      tech
      Hello
      Here's my question, I'm using Daze's sensor sentinel and for the sensor filament function or exactly do I have to put the code M581?
      Thanks,
      Best Regards
      Chris
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M581_Configure_external_trigger
        You can set that up in config.g
          Filament sensors are normally configured using M591 these days. M581 was used before M591 was introduced.
