    lines on the LCD
    • pabomanundefined
      paboman
      Sometimes, without touching the printer, my 4.3" LCD shows only lines.
      the printer continue to print without issue but also the network become unresposnive.
      I am running the last available firmware
      The LCD cable was shortened to 20cm because the sceen is near the Duet board.
      how can I solve this problem ?
      thank you
      • A Former User?
        A Former User
        Which LCD cable? The 40 pin one between the PanelDue and the LCD? Surely that wasn't longer than 20cm to begin with?
        If you're talking about the 4 pin one between the Duet and the PanelDue then that is no problem, and wouldn't cause that symptom.
        I'd examine the flexible cable/pcb thing between the LCD panel and the PCB for the LCD panel, then check the 40 pin cable is properly inserted.
        pabomanundefined 1 Reply Last reply Reply Quote 0
        • pabomanundefined
          paboman @A Former User
          @bearer
          both cable was shortened.
          the flexible cable also was shortned but i am not printing with external SD card, do you think this can still be an issue if not crimped well enough?
          • A Former User?
            A Former User
            None of the cables between the Duet main board and the PanelDue will cause that problem.
            Only the ribbon cable and flex cable on the PanelDue itself would result in something like that, or possibly firmware issues as well, but i think the latter is unlikely.
            • A Former User?
              A Former User
              Whops, just remembered, there is no ribbon cable on the PanelDue, thats just my setup due to space constraints, my bad.
              But there is a yellowish thin flex cable from the actual LCD panel, to the PCB behind the LCD panel. Thats the likely offender IMO.
              Looks a bit like so: 0_1562852804348_e11705a0-a213-405b-8800-e52ecaa4d505-image.png
              pabomanundefined 1 Reply Last reply Reply Quote 1
              • pabomanundefined
                @bearer
                thank you, I will check this
                • pabomanundefined
                  paboman
                  I have removed, cleaned with IPA and reinstered the yellowish flex cable.
                  Hope this will solve the lines problem, as always intermittent issues are hard to track down
