    coreXY movement, stall detection
    • Donpiundefined
      Donpi
      Hi all,
      I start a new topic because my last issue is solved.
      So now that everything seem to move as it should I have a reverted axis...
      X and Z are wrong direction while Y is ok.
      I tried to change direction with M569 in config.g for X motor but in this case X is ok and Y is reverted.
      And changing Z direction do not change anything.
      After updatting to firmware 2.03, Z and X is ok but Y still wrong direction.
      I tried all the binary combination of direction with the X and Y without succes.
      I try to set my origin in the bottom left corner of the bed.
      Is ther an M something to revers the axis direction instead of the motor ?
      In any case stall detection do not work.
      Can somone help ?
      Thanks
      PS: My english os a bit low, so tell me if you need me to explain something unanderstandable.
        see https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter#Section_Movement_section
        • Scachiundefined
          Scachi
          You should setup the correct movement first before trying to do stall detection or any other fancy stuff.
          This page mentions how to setup, test the x and y motor directions, what connections to swap or directions to change to get the correct result:
          // I am too slow 😉
          • Donpiundefined
            Donpi
            Haha I missed the part with switching the cables.
            Now it's good, including stall detection.
            Thank you
