    Baby stepping not indicated ?
    • Johncoffeeundefined
      Johncoffee
      Quick question:
      When I set baby stepping e.g. -0.06mm, this isn't indicating in the Z position at the head position Why not?
      I would expect that my current position : 0.8mm as layer no.4 of my print would change to 0.74mm?
      Finally upgraded my trusty Rostock Max V2 from Rambo v1.4 to Duet Wifi & 7" screen & BLtouch sensor. Installed end of June 2019
      Prusa Mk2 MMU1.0
      • oliofundefined
        oliof
        There has been a discussion on baby stepping in the recent past. I deem it a good read.
          Johncoffee
          Thanks a lot - will check this.
          Prusa Mk2 MMU1.0
            There are two sets of coordinates: user coordinates and machine coordinates. Currently, DWC displays only the user coordinates, which are the coordinates that the GCode file you are printing commands. DWC has access to the machine coordinates as well, so future version may give you the option of displaying them. Meanwhile, if you send M290 then it will report the current babystepping.
