Hypercube homing positions?
  • Programming duet for my new HEVO I built, first scratch built printer.
    Does it matter which corner I setup the endstops in? does the standard configuration home to the left front or left rear etc is my question?
  • From a theoretical point of view, no, it doesn't matter. You can home to literally any position, doesn't even need to be a corner.
    Regardless of where you home, you do need to take care to follow conventions for placing the origin (0,0,0), or your parts may be mirrored. (or compensate in the slicer)
  • ok I think I figured out the front left is the standard position. Was just trying to figure out how to fabricate the endstops and where
  • Yeah, but you don't have to home to the origin, you can home to any combination of Xmin/Xmax/Ymin/Ymax/Zmin/Zmax.
    It is worth considering Zmin/Zmax and weather or not homing while there is a print on the bed can be an issue.
