Hotend PID tuning
  • Hi guys,
    I'm not sure what i'm doing wrong here, i'm trying to PID tune a 12v 30w E3D hotend,
    I'm sending command,
    M303 H1 S280 P0.1
    But getting error,
    Error: Temperature reading fault on heater 1: temperature above limit
    no matter what P setting i use i get the same error.
    Any suggestions? I can't set S any higher because i get,
    Bad parameter in M303 command
    Cheers
    Charlie.
    It looks to me that you have a massively over-powered heater. Are you using a 12V heater cartridge on 24V power?
    You can increase the temperature limit if you need to using the M143 command. The default is 262C.
  • You got me worried there, had to double check. It's definitely wired to 12v.
    I'll try M143 and report back.
    Cheers
    You can also reduce the P parameter to below 0.1 if you need to. Or try the 1.18 beta firmware, which doesn't need a P parameter when auto tuning, just a target temperature (which will be overshot somewhat).
  • I went for the new 1.18beta, it did give a warning,
    Warning: Heater 1 appears to be over-powered and a fire risk! If left on at full power, its temperature is predicted to reach 602C.
    Saved with M500.
    Cheers
    Charlie.
