    Base config for Z axis for alignment
    My Duet controlled machine
    • PaulHewundefined
      PaulHew
      I am building my RailCore and would like to put some base code in the Duet so I can run my Z axis leadscrews independantly whilst I align the linear rails.
      I was going to use an electric drill on the exposed Z leadscrew, but thought better of that idea!
      Thanks in advance.
      Paul.
      RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
      Voron 2.4 disassembled..... Waiting for the RailCore Mini....
        The simplest approach is to assign each Z motor to be an independent axis. If you have your Z motors connected to the Z E0 E1 connectors on the Duet (and the extruders connected to the DueX), you would normally have this command or similar in config.g:
        M584 X0 Y1 Z2:3:4 E5:6:7:8:9
        To make the motors controllable as axes Z U V, use this instead:
        M584 X0 Y1 Z2 U3 V4 E5:6:7:8:9
        Temporarily put this in homeall.g:
        G92 X0 Y0 Z0 U0 V0
        then the firmware will consider that all axes have been homed and it will allow you to jog them.
        PaulHewundefined 1 Reply Last reply Reply Quote 0
        • PaulHewundefined
          PaulHew @dc42
          @dc42 Thank You, appreciated.
