DuetWifi 1.01 Updated to 1.24 - No Z Axis after update
@dirtybirdnj said in DuetWifi 1.01 Updated to 1.24 - No Z Axis after update:
Still need to run M564 H0 before z-axis is unlocked
Repost your homing files. There is a G1 move in there somewhere that needs S2.
I just commented out their contents
What did they contain?
@phaedrux said in DuetWifi 1.01 Updated to 1.24 - No Z Axis after update:
I copied the contents of the files over to a scratch pad before I commented them out, here they are. I don't recall setting these up so it seems like something that was on the SD card that the previous firmware didn't run / care about? Not sure... either way I am elated that I had two successful prints tonight!
// deployprobe.g ; Probe deployment routine for Mini Kossel M564 S0 ; don't apply limits G1 X25 Y93 Z40 F10000 ; put probe arm next to belt G1 X-5 F500 ; move probe arm across belt G1 X12 F1000 ; move probe back G1 X0 Y0 F10000 ; move to somewhere sensible M564 S1 ; apply limits again //retractprobe.g ; Probe retraction routine for Mini Kossel M564 S0 ; don't apply limits G1 Z40 F10000 ; raise head G1 X-59 Y66 Z35 ; move over the post G1 Z7 F500 ; push probe down on post G1 Z35 F10000 ; raise head again G1 X0 Y0 ; move to somewhere sensible M564 S1 ; apply limits again
After taking a look at these I can clearly see it's setting
M564 S1
at the end of each which is prob what was causing the "axes not homed" errors! I commented out theM654 H0
in myconfig.g
and it homes the Z with no problem now. These files also account for the "random" x+y movements that were happening with the homing process as well... mysteries solved and case closed.This thread can be marked solved! Thanks again to @dc42 @Phaedrux for your help!
Glad it's all working now.
