    Starting a print from Panel Due
    358
    • hussainsail2002
      hussainsail2002 last edited by hussainsail2002
      Just received my duet wifi 2 and panel due.
      I uploaded a Gcode file from my web browser and tried accessing the same from the Panel due screen,
      It does not seem to show. Also I tried inserting a micro sd card with gcode files on it but the screen shows that no sd card is available.
      I have not attached any components to the board yet, just wanted to test it out the panel due before starting the build.
      Also is there any way to model the UI for the paneldue
      Thanks!,
      Hussain.
      Stephen6309 1 Reply Last reply Reply Quote 0
      • Stephen6309
        Stephen6309 @hussainsail2002 last edited by Stephen6309
        @hussainsail2002 The panel due shows the gcode files on the sd card that's on the Duet board. The PanelDue sd card slot needs the Duet to access the files on there, as long as the appropriate cable is attached.
        • hussainsail2002
          I attached both the 4 pin cable as well as the 10 pin ribbon cable, The uploaded files should show at the print screen right ??, but it does not seem to be showing up there.
          Additional I put in a separate SD card into the Panel due and I am unable to access the files there as well.
          I have yet changed any config files or attached any hardware to the board yet.
          Just wanted to know if this is normal.
          Regards,
          Hussain.
          • Stephen6309
            @hussainsail2002 On the PanelDue, go to the Control tab, the sd card button is to the left of the move button. You won't be able to access them from the Print tab. Your photo didn't show up the first time.
            • hussainsail2002
              ya I tried the clicking on the SD card button on the control tab as well, its says that there are no files.
              Danal 1 Reply Last reply Reply Quote 0
              • Danal
                Danal @hussainsail2002 last edited by
                @hussainsail2002 said in Starting a print from Panel Due:
                That is the correct button. What do you see in the web interface, when you look for gcode files?
                hussainsail2002 1 Reply Last reply Reply Quote 0
                • A Former User
                  A Former User last edited by
                  Picture says "connecting" in the top right corner of the screen. Would suggest Duet and PanelDue aren't communicating.
                    Probably best to use the 4 wire cable and leave the 10 wire cable disconnected.
                    • A Former User
                      Is the PanelDue serial port configured in config.g?
                      https://duet3d.dozuki.com/Wiki/Gcode#Section_M575_Set_serial_comms_parameters
                      • hussainsail2002
                        hussainsail2002 @Danal last edited by
                        @danal On the web interface on the PC I can see my file has been uploaded
                        • hussainsail2002
                          hussainsail2002 @Guest last edited by
                          @bearer I have not set the config files yet, I just connected everything out of the box as soon as I received it, Do I need to set the config.g first ?
                            Normally, a PanelDue connected to a Duet just works, because both use the same default baud rate, which is 57600. So go to the Setup page of PanelDue and check that the baud rate is 57600. Also send M575 P1 to the Duet from USB or Duet Web Control, and check that it reports the baud rate is 57600.
                            If the baud rates are correct, then it's usually a wiring issue. It's simplest to use the ribbon cable, but make sure you plug it into CONN_SD on the Duet, not CONN_LCD.
                            • hussainsail2002
                              hussainsail2002 @dc42 last edited by
                              @dc42 will do,
                              Shouldn't the files uploaded from the web browser show under the print tab ? Irrespective of whether the panuel due SD card is connected ?
                              • A Former User
                                Does the panel still say "Connecting" in the top corner? It should change to "connected" or "ready" or something like that once the PanelDue and Duet boards are communicating.
                                • hussainsail2002
                                  @bearer It just keeps saying connecting, it does not change
                                  • A Former User
                                    You're not gonna see anything from the Duet on the PanelDue until you figure out if you've wired it wrong or its configured wrong (or possible but unlikely, something is defective)
                                    • hussainsail2002
                                      @bearer okay, will go through the wiring's again and also upload the config files ...
