Duet wifi v1.04, upgraded reprap firmware 2.03
  • Duet wifi v1.04,
    Good day. I upgraded the duet2 wifi to reprap firmware 2.03 (2019-06-13b2). When I turn on the printout from ABS, the fans turn on 78%. How to turn it off?
    The fans are turned off in the blowmistress. in config I have:
    M106 P1 H-1 S0;
    M106 P2 H-1 S0
    The firmware was fine before the change
  • Moderator
    Can you post your config.g?
  • ; Configuration file for Duet WiFi (firmware version 1.21)
    ; generated by RepRapFirmware Configuration Tool v2 on Sun Feb 24 2019 22:58:40 GMT+0100 (czas środkowoeuropejski standardowy)
    M111 S0;
    G21
    M82 ; ...but relative extruder moves
    M550 P"GIANTS" ; Set machine name
    M552 S1 ; Enable network
    M587 S" ; Configure access point and IP addresses. You can delete this line once connected
    M586 P0 S1 ; Enable HTTP
    M586 P1 S0 ; Disable FTP
    M586 P2 S0 ; Disable Telnet
    M569 P0 S1 ; Drive 0 os X
    M569 P1 S0 ; Drive 1 os Y
    M569 P2 S1 ; Drive 2 os Z
    M569 P3 S1 ; Drive 3 os U
    M569 P4 S1 ; Drive 4 os Y
    M569 P5 S0 ; Drive 5 ekstruder lewy
    M569 P6 S0 ; Drive 6 ekstruder prawy
    M584 X0 Y1:4 Z2 U3 E5:6 ; U Dodatkowy silnik w osiX
    M350 X32 Y32:32 U32 Z256 E64:64 I0 ; Configure microstepping
    M92 X160.85 Y160.75:160.75 U160.85 Z25800 E370:370 ; Set steps per mm
    M566 X300.00 Y300.00:300.00 U300.00 Z12.00 E120.00:120.00 ; Set maximum instantaneous speed changes (mm/min)
    M572 D0 S0.015
    M572 D1 S0.015
    M203 X10000.00 Y10000.00:10000.00 U10000.00 Z200.00 E1200.00:1200.00 ; Set maximum speeds (mm/min)
    M201 X3000.00 Y3000.00:3000.00 U3000.00 Z100.00 E250.00:250.00 ; Set accelerations (mm/s^2)
    M906 X1400.00 Y1200.00:1200.00 U1400.00 Z1700.00 E1700.00:1700.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S0 ; Set idle timeout
    M564 S1 H0 ; Set idle timeout
    M208 X316 Y285 U317 Z250 ; Set axis maxima
    M208 X-60 Y0 U0 Z0 S1 ; Set axis minima
    M558 P0
    M574 X1 Y1 U2 Z1 S1 ;krancowka U na maksimum
    M307 H0 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit
    M305 P0 T100000 B4635 C9.503333e-8 R4700 ; Set thermistor + ADC parameters for heater 0
    M305 P1 T100000 B4635 C9.503333e-8 R4700 ; Set thermistor + ADC parameters for heater 1
    M143 H1 S253 ; Set temperature limit for heater 1 to 253C
    M305 P2 T100000 B4635 C9.503333e-8 R4700 ; Set thermistor + ADC parameters for heater 2
    M143 H2 S253 ; Set temperature limit for heater 2 to 253C
    M106 P0 S200 ; Wentylator chloszenia elektroniki, lewy przod
    M106 P1 H-1 S0 ; Wentylator chlodzenie wydruku lewy
    M106 P2 H-1 S0 ; Wentylator chlodzenia wydruku prawy
    M106 P3 S1 I0 F500 H1 T45 ; Ustaw wartosc wentylatora 1, odwrocenie i czestotliwosc sygnału PWM. Sterowanie termostatyczne jest wlaczone
    M106 P4 S1 I0 F500 H2 T45 ; Ustaw wartosc wentylatora 2, odwrocenie i czestotliwosc sygnału PWM. Sterowanie termostatyczne jest wlaczone
    M106 P5 S200 ; Wentylator chlodzenia elektroniki, lewy tyl
    M106 P6 S200 ; Wentylator chlodzenia elektroniki, prawy tyl
    M106 P7 S200 ; Wentylator chlodzenia elektroniki, prawy przod
    M106 P8 S80 ; Uruchom wentylator HEPA z limited predkoscia
    M563 P0 D0 H1 F1 ; narzedzie 0 uzywa wytlaczarki 0, grzejnika 1 i wentylatora 1
    G10 P0 X0 Y0 Z0 S0 R0 ; ustaw korekcje narzedzia i temperatury
    M563 P1 D1 H2 X3 F2 ; narzedzie 1 wykorzystuje wytlaczarke 1, podgrzewacz 2, wentylator 2 i odwzorowuje X na U
    G10 P1 Y0.7 U0 Z0 S0 R0 ; ustaw przesuniecia 1 narzedzia i temperatury
    M563 P2 D0: 1 H1: 2 X0: 3 F1: 2 ; narzedzie 2 wykorzystuje zarowno wytlaczarki, podgrzewacze ciepla i wentylatory, jak i odwzorowuje X na X i U
    G10 P2 X40 Y0 U-40 Z0 S0 R0 ; ustawic korekcje narzedzi i temperatury
    M567 P2 E1: 1 ; ustawic stosunek mieszania 100% na obu wytlaczarkach
    M501
    T0 ; Select first tool ; Select first tool
  • Moderator
    If it's turning on during a print is the slicer turning it on?
    Can you post the gcode you're trying to print? Or look through it for m106 commands.
  • ; KISSlicer - PRO
    ; Windows
    ; version 2 a 0.4.4 Win64
    ; Built: Jul 7 2018, 11:14:03
    ; Running on 4 cores
    ; Saved: 2019-07-18 20:21:29
    ; 'PI3_mitsubishiL mitsubishiPP.gcode'
    ; Anti-shrink gain x=1.000000, y=1.000000, z=1.000000
    ; *** Printer Settings ***
    ; printer_name = Tryb kopii - ABS
    ; profile_date = 2019-07-18 20:20:59
    ; bed_STL_filename =
    ; extension = gcode
    ; cost_per_hour = 0
    ; g_code_prefix = 473231200A473930200A4D3832200A4732380A473120
    ; ^ 5A350A54320A54203C455854202B20313E0A4D3134302053203C4245
    ; ^ 443E200A4D313136200A4D3130342053203C54454D503E200A4D3130
    ; ^ 392053203C54454D503E200A4D3130342053203C54454D503E0A5432
    ; ^ 20
    ; > Decoded
    ; > G21
    ; > G90
    ; > M82
    ; > G28
    ; > G1 Z5
    ; > T2
    ; > T <EXT + 1>
    ; > M140 S <BED>
    ; > M116
    ; > M104 S <TEMP>
    ; > M109 S <TEMP>
    ; > M104 S <TEMP>
    ; > T2
    ; g_code_preheat = 3B20686561742074686520286E6578742C207468656
    ; ^ E2063757272656E742920657874727564657220776974686F7574207
    ; ^ 7616974696E670A3B4D31303420533C54454D503E20543C4558542B3
    ; ^ 03E0A3B20556E636F6D6D656E74207468652070726576696F7573206
    ; ^ C696E6520746F20656E61626C6520707265686561740A
    ; > Decoded
    ; > ; heat the (next, then current) extruder without waiting
    ; > ;M104 S<TEMP> T<EXT+0>
    ; > ; Uncomment the previous line to enable preheat
    ; g_code_warm = 3B204865616420746F20746865207374617274206F6620
    ; ^ 746865206E65787420706174680A3B473120583C4E455854583E2059
    ; ^ 3C4E455854593E2046363030300A3B47342050300A3B2053656C6563
    ; ^ 742074686520546F6F6C20286578747275646572290A3B543C455854
    ; ^ 2B303E0A3B20436F727265637420706F736974696F6E20666F72206D
    ; ^ 756C74692D6E6F7A7A6C650A3B473120583C4E455854583E20593C4E
    ; ^ 455854593E2046363030300A3B47342050300A3B205365742074656D
    ; ^ 7020616E64207468656E20776169740A3B4D31303420533C54454D50
    ; ^ 3E0A3B4D31303920533C54454D503E0A3B205055524745204F522050
    ; ^ 52494D45204845524520494620444553495245440A
    ; > Decoded
  • Why does this record not turn off the fans?
    M106 P1 H-1 S0
    M106 P2 H-1 S0
    After all, it shows that the thermostat is turned off
  • Moderator
    That gcode section doesn't show enough to see if it's sending any M106 commands. I suggest you open the gcode file in a text editor and searching for M106
  • Problem solved.
    I added M107 to the kisslicer
    Thank you for your help
