    Long "processing" time after uploading moderately large gcode file
    • Yonkiman
      Yonkiman last edited by
      I uploaded a 16MB gcode file to my Duet Wifi about 15 or 20 minutes ago. "Size" is reported correctly, but "Object Height", "Layer Height", "Filament Usage", and "Generated by" are still stuck at "loading". Is something wrong or do I just need to wait longer?
      Firmware Version: 1.18beta1 (2017-02-21)
      WiFi Server Version: 1.03 (ch fork)
      Web Interface Version: 1.14a
      • T3P3Tony
        Can you try with the beta3 firmware please
        www.duet3d.com
        • Yonkiman
          Just tried beta3 - same problem.
          • Yonkiman
            Looks like it was the filename (too long?).
            Hangs: [c]Fred's Voron Power Supply (Voron Print).gcode[/c]
            Works: [c]Voron PSU 2.gcode[/c]
              I think it's the quote character in the filename that is the problem. I thought this was fixed a little while ago. Did you also upgrade DWC to version 1.15?
              • Yonkiman
                Ah…didn't know a new DWC had dropped.
                Yes, the file loads and displays correctly with 1.15.
