endstop to kill print
how would i use a spare endstop to trigger the printer to turn all motors and heaters off? i have a water flow sensor to monitor the hotend in case the pump fails, i read the one thread about using a 555 timer as a missing pulse detector, but there a two or three ways of making one and im not very good with circuitry. so i had a friend make an arduino code that converts the pwm from a hall sensor to high or low output. so can i send that on or off output to and endstop to kill a print?
if you connect PIN 44 on the expansion header to ground, you will trigger an emergency reset. This will turn everything off.
An example for this with mechanical buttons is up on the wiki: https://duet3d.dozuki.com/Wiki/Using_M581_-_External_Triggers_and_Building_a_Control_Panel but instead of a push button you could of course use some kind of sensor that closes the circuit.
This post is deleted!
if im reading this right i could put this code in my config
M581 E1 S1 T0 C0
and connect the sensor output to endstop E1 right?
That should work
can the endstop input take 5v? or do i need a step down converter?
which board?
https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches
If you are using either the Duet 2 Maestro or hardware version 1.04 of the Duet 2 WiFi/Ethernet, these boards can tolerate 5V on the endstop inputs.
@deltajegga said in endstop to kill print:
You can not use a step down converter for such task.
They take to much to power up and will draw to much current from the endstop.
You can use a voltage divider or some diodes to drop-down the voltage
good news!! it totally works perfectly. i just used a few diodes to drop the voltage. should i make a post somewhere explaining how to make a water flow sensor auto kill?
Yes, please add it to the wiki.
