    IR Probe issue
    • Prawnabie
      Prawnabie last edited by
      Hi all,
      I am currently configuring my IR probe and cant seem to get it to home my Z axis properly..
      The edge of the board it just over 1mm higher than the nozzle and I get 4 flashes when I switch the machine on. I am also using blue tape on the bed under the sensor. I get a reading of 0 with nothing under the sensor, 4.65 with a piece of paper near the sensor and 538 when the led lights up.
      I send M558 P1 followed by G31 P500 Z1.0, then lower the head to grab a piece of paper and send Z92 Z0 to the printer, raise the head by 5mm and then send G30 S-1 which gives me a head height of 2.84mm. I enter the value into my G31 line in the config.g and cycle the power but the head always homes to 2.84 and obviously this is over a couple of mm too high. Am I missing something as the way I see it the firmware knows I want to home at 0 hence the g92 command and it knows the trigger height - what am I missing to make it get to 0 once the sensor triggers?
      Thanks in advance!
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      M667 S1 ; Select CoreXY mode
      M208 X290 Y100 Z100 S0 ; Set axis maxima
      M574 X1 Y2 Z0 S0 ; Define active low and unused microswitches
      M558 P1 X0 Y0 Z1 H5 F200 T5000 ; Set Z probe type to analog, the axes for which it is used and the probe + travel speeds
      G31 P500 X0 Y0 Z2.84 ; Set Z probe trigger value, offset and trigger height
      M557 X15:85 Y15:85 S20 ; Define mesh grid
      M569 P0 S0 ; Drive 0 goes backwards
      M350 X16 Y16 Z16 E16 I1 ; Configure microstepping without interpolation
      M92 X100 Y100 Z400 E418.5 ; Set steps per mm
      M203 X5000 Y5000 Z180 E1200 ; Set maximum speeds (mm/min)
      M201 X2000 Y3000 Z250 E250 ; Set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I60; Set motor currents (mA) and motor idle factor in per cent
      M84 S60 ; Set idle timeout
      M143 S290 ; Set maximum nozzle heater temperature to 250C
      M307 H0 A410.7 C190.6 D5.0 B0 ; Bed heater autotune results
      M307 H1 A516.2 C193.2 D5.5 B0 ; Nozzle heater autotune results
      M305 P0 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 0 (Bed)
      M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1 (Nozzle)
      M563 P0 D0 H1 ; Define tool 0
      M550 PCoreXY ; Set machine name
      M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
      M106 P0 S1 I0 F500 H1 T40 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P1 S0 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P2 S0 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
      T0 ; Select first tool
      • Willy510
        Willy510 last edited by
        The mini IR sensor on my printer always stops Z at the triggered height when homing and running an auto level. The G31 Z offset is the amount past that triggered height that Z will move when printing. Have you tried printing anything?
          The purpose of homing is to establish a known position, which does not need to be zero. Your printer is homing correctly. If you want it to end up at Z=0 after homing, you can add command G1 Z0 to the end of homeall.g and homez.g. But it's not necessary.
          • Prawnabie
            Ahhh I get it now!! So the trigger height is just a reference position and the z0 command will be given to the printer when printing by the slicers g code?
            • deckingman
              deckingman last edited by
              @Prawnabie:
              Mostly correct but actually the first Z move will be to the Z position that corresponds to your first layer height is - i.e something like G1 Z0.3.
