    Setting up wifi on Duet Wifi
    wifi
    • MacNite
      MacNite last edited by
      I have a problem adding / modifing the wifi on my Duet 2 Wifi. I get following message:
      Any suggestions on what I did wrong? It was working fine previously but I got a new router and had to setup everything again.
      Greets
      Max
      CorEssentials on GitHub | Instructables Profile | Thingiverse Profile
      • A Former User
        A Former User last edited by
        Not familiar with the Duet Wifis, but recall there is an issue if your SSID is hidden?
        And I know in general the ESP8266 wifi isn't compatible with all of the latest encryption schemes, but I don't recall of the top of my head which doesn't work.
        Add information about your wireless network, everything but the key please, and someone might know more.
        • MacNite
          @bearer said in Setting up wifi on Duet Wifi:
          I don't know if that is the problem - the Duet Wifi will connect with the same wifi repeater as before, only the Password is different:
          Wifi SSID: Wirless Witichis Repeater
          Frequency: 2,4 GHz
          Encryption: WPA2
          If you need any other information say so - I am not really good with networking 😄
          I don't know what happend and what "bad reply format version" means.
          Greets
          Max
            Try using M588 S"*" to delete the existing known networks before you use M587 to add the new one. Also please tell us the main firmware and WiFi firmware versions you are using.
            MacNite 1 Reply Last reply Reply Quote 0
            • MacNite
              MacNite @dc42 last edited by
              I tried
              M588 S"*"
              I get the same response with "bad reply format version". I can't access DuetWeb Control - where can I get the firmware + Wifi Version numbers?
              Greets
              Max
              • droftarts
                droftarts administrators last edited by
                If you've updated your firmware recently, it may have got out of sync with the supported version of the Wifi firmware. Sending M122 will produce the Diagnostic report. In that there will be the RepRapFirmware version:
                >>>m122
                SENDING:M122
                RepRapFirmware for Duet 2 WiFi/Ethernet version 2.04RC1 running on Duet WiFi 1.0 or 1.01
                and in the last section under '- WiFi -' will be the WiFi firmware version:
                WiFi firmware version 1.23
                This report doesn't show the version of the Duet Web Control. To update the Duet firmware, WiFi firmware and DWC version, see https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware
                • MacNite
                  I got it working now.
                  Is it possbile, that I have to de-activate the wifi module (M552 S0) befor I use M587 S"..." P"..."? I use M552 S1 in my config.g as standard.
                  What I did to solve the problem:
                  • update to the most recent firmware --> did not help
                  • restartet the printer multiple times --> did not help
                  • disabled wifi with M552 S0, removed all previous connections with M588S"*", added new connection with M587 S"..." P"...", enabeld wifi using M552 S1
                  Now it works fine.
                  Have a nice weekend,
                  Max
