    Having issues with homing Z on CoreXY
    • equanimity8
      equanimity8 last edited by
      Hello all,
      After a being away from the hobby for some time I now have the opportunity again to fiddle with a custom CoreXY I started designing a while back. The machine is now built and wired and I started setting up the firmware but ran into some issues, mainly with homing the Z axis.
      The machine is a custom CoreXY on v-wheels for X and Y and triple leadscrew with rods with printed bushings for Z. I'm running a Titan direct extruder and piezo for Z endstop and Z compensaiton. The firmware is updated to 2.03 from 1.21.
      The problem I run into is an unusual behavior during the Z homing procedure (which comes after X and Y in the homeall.g). The printer homes Z which moves the bed to a negative value where the piezo triggers and moves the bed to Z10 although the gcode that I have setup is supposed to move the bed to Z5.
      The issue is rather perplexing and I can certainly video it but I suspect that the more experienced of you will spot a mistake in the gcode that I simply cant find with my limited time on RRF, hence I'm asking for some help.
      Here I will put my config.g and homeall.g:
      config.g
      M667 S1 ; Select CoreXY mode
      M550 PPrinter Extrusions ;machine name
      M552 S1 ;start wifi module
      M92 X80 Y80 Z2133.33 E456 ; Set steps per mm
      M566 X900 Y900 Z1 E120 ; Set maximum instantaneous speed changes (mm/min)
      M203 X6000 Y6000 Z720 E1200 ; Set maximum speeds (mm/min)
      M201 X500 Y500 Z250 E250 ; Set accelerations (mm/s^2)
      M906 X1300 Y1300 Z1300 E1000 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X200 Y200 Z350 S0 ; Set axis maxima
      M574 X1 Y1 Z0 S0
      M558 P8 H10 I1 R1 F400 X0 Y0 Z1
      G31 X0 Y0 Z-2.5 P600
      M140 H-1 ; Disable heated bed
      M106 P1 H-1 ; set fan 1 to be gcode controlled
      M106 P2 S1 I0 T45 H1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M563 P0 D0 H1 ; Define tool 0
      M375
      homeall.g
      ;Home X and Y
      G91 ; relative positioning
      G1 Z5 F420 S2 ; Lower bed 5mm to ensure it is below the switch trigger height
      M913 X100 Y100 ; set X Y motors to 50% of their normal current for homing
      G1 S1 X-375 Y-305 F600 ; course home X or Y
      G1 S1 X-375 F600 ; course home X
      G1 S1 Y-305 F600 ; course home Y
      G1 X5 Y5 F600 ; move away from the endstops
      G1 S1 X-10 F200 ; fine home X
      G1 S1 Y-10 F200 ; fine home Y
      G1 X5 Y5 F600 ; go to origin
      M913 X100 Y100 ; set X Y motors to 100% of their normal current
      ;Home Z
      G90 ; absolute positioning
      G1 X30 Y30 F600 ; go to first probe point
      G1 Z5 F420 ; lift Z relative to current position
      • Stephen6309
        Stephen6309 last edited by
        Your dive height is 10mm, so it moves to that height in preparation for a probe.
        • equanimity8
          My mistake, the printer moves Z to 15, not 10 (I suppose it was a bit late). In anycase, you were right about where this is coming from. I commented out "G1 Z5 F420 ; lift Z relative to current position" in ;Home Z to isolate the effect of dive and played around with different values and the movement of the bed corresponds to that. I'm not sure I'm understanding the way this works, though. Isn't moving to the dive height something should happen when probing is commanded and not after homing all axes?
          Stephen6309 1 Reply Last reply Reply Quote 0
          • Stephen6309
            Stephen6309 @equanimity8 last edited by
            @equanimity8 You're using the probe to home Z.
            • equanimity8
              Yeah, so true when I think about it. Not really used up to a setup like this. Thank you @Stephen6309 for your time and for spelling it out for me.
