    bltouch randomly stops working
    • kmhudgins
      kmhudgins last edited by
      So after having the bltouch working for a while it has started to randomly stop working.
      i have replaced the whole wiring harness to make sure it was not a wiring issue.
      I after shutting my ender down unplugging the bltouch re connecting it. the bltouch will work some times a few prints sometimes not even enough to probe the bed. I was thinking that this could either be the bltouch itself or maby the ports on the duet maestro board. any thoughts?
      thank you
      Ky Hudginss
      • kmhudgins
        also taking suggestions for a better auto level solution for ender 3
        • DIY-O-Sphere
          DIY-O-Sphere last edited by DIY-O-Sphere
          Hi Ky,
          I had exactly the same issue, that was driving me crazy....
          Check the Pin
          "Try loosening or tightening the set screw slightly to adjust the trigger sensitivity."
          There is a description how to set up the srew, but I can't find it currently.
          In the end a quarter turn had reliably solved the problem.
          Regards
          Frank
          Edit:
          You can find the information in the manual
          • kmhudgins
            thank you that helped.
