Wifi 2 SPI Timeout
Hi Duet people! I'm trying to get started with my first Duet Wifi 2 and struggling to get my wifi working. The SPI error is concerning to me - I was unable to get the Duet to via the original firmware, so I tried updating.
Here's a log I captured after updating the both theDuet2CombinedFirmware.bin
at2.04RC1
andDuetWiFiServer.bin
at2.03
:RepRapFirmware for Duet 2 WiFi/Ethernet Version 2.04RC1 dated 2019-07-14b1 Executing config.g...Error: M587: Failed to add SSID to remembered list HTTP is enabled on port 80 FTP is enabled on port 21 TELNET is disabled Warning: Macro file config-override.g not found. Done! RepRapFirmware for Duet 2 WiFi/Ethernet is up and running. WiFi module started Error: Temperature reading fault on heater 1: sensor open circuit WiFi reported error: no known networks found WiFi module is idle === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 2.04RC1 running on Duet WiFi 1.02 or later + DueX2 Board ID: 08DGM-917DA-G4MSJ-6JKFJ-3SJ6N-TBRB9 Used output buffers: 1 of 24 (9 max) === RTOS === Static ram: 25680 Dynamic ram: 94104 of which 460 recycled Exception stack ram used: 288 Never used ram: 10540 Tasks: NETWORK(ready,1244) HEAT(blocked,916) DUEX(suspended,156) MAIN(running,3844) IDLE(ready,160) Owned mutexes: === Platform === Last reset 00:09:33 ago, cause: power up Last software reset details not available Error status: 0 Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest block write time: 0.0ms, max retries 0 MCU temperature: min 29.0, current 31.3, max 31.5 Supply voltage: min 1.6, current 1.7, max 1.8, under voltage events: 0, over voltage events: 0, power good: no Driver 0: ok, SG min/max not available Driver 1: ok, SG min/max not available Driver 2: ok, SG min/max not available Driver 3: ok, SG min/max not available Driver 4: ok, SG min/max not available Driver 5: ok, SG min/max not available Driver 6: ok, SG min/max not available Date/time: 1970-01-01 00:00:00 Cache data hit count 1140769362 Slowest loop: 0.28ms; fastest: 0.07ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Move === Hiccups: 0, FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms Bed compensation in use: none, comp offset 0.000 === DDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 0 Stack records: 1 allocated, 0 in use Movement lock held by null http is idle in state(s) 0 telnet is idle in state(s) 0 file is idle in state(s) 0 serial is ready with "M122" in state(s) 0 aux is idle in state(s) 0 daemon is idle in state(s) 0 queue is idle in state(s) 0 autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 0.24ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0) HTTP sessions: 0 of 8 - WiFi - Network state is changing mode WiFi module is idle Failed messages: pending 0, notready 0, noresp 1 WiFi firmware version 1.23 WiFi reported error: no known networks found WiFi module is idle WiFi MAC address ec:fa:bc:25:34:8f WiFi Vcc 3.43, reset reason Turned on by main processor WiFi flash size 4194304, free heap 26088 Socket states: 0 0 0 0 0 0 0 0 ok Error retrieving WiFi status message: SPI timeout WiFi reported error: no known networks found WiFi module is idle M587: Failed to retrieve network list ok Error retrieving WiFi status message: bad reply format version
Edit:
I foundM111 S1 P14
lists wifi networks around the printer, howeverM587 S"mywifinetwork" P"my wifi password"
gives:Executing config.g...Error: M587: Failed to add SSID to remembered list
and a bare M587 claimsM587: Failed to retrieve network list ok Error retrieving WiFi status message: bad reply format version
then returns to the every couple seconds spewing
This morning I downgraded the main firmware to 2.03 just to rule out any weirdness with a mismatched function from the 2.03 wifi firmware. Same sad state unfortunately. What information can I provide to help?
https://duet3d.dozuki.com/Wiki/Gcode#Section_M588_Forget_WiFi_host_network
I just went through all the network library again and saw this little footnote. So I read the gcode that came out of the configurator and noticed that it does not use a
M552 S0
. So I added; Network M552 S0 ; Put wifi in idle mode. If you don't do this apparently it does not start up.
and it does connect now. I don't know why the module does not seem to turn on with the configurator-provided
M552 S1
but hey it turns on now and I can reach the web interface. -
Curious was this all done through config.g and not the serial port?
Important! Do not use M587 within config.g. As well as being a security hazard, writing the access point parameters to WiFi chip every time you start the Duet may eventually wear out the flash memory. Also, the wifi module does not get enabled until the end of running config.g. It is better to use a macro to send M587 (source: https://forum.duet3d.com/post/42798)
The firmware configuration tool spat out m587 into config.g yes. Through trial and much error I took it out and ran that via serial. The m587 seems to have been somehow poisoning the startup of the wifi chip.
Thats unfortunate. Wonder how that could be adressed to avoid others experiencing the same thing.
At least you got it working in the end though!
@krohelm said in Wifi 2 SPI Timeout:
The firmware config tool should not put M587 commands in config,g. We're looking into it.
Could introduce wifi.g to be executed after config.g if no networks are stored in the wifi module maybe? Would simplify the setup being able to put it all on the sd card, and it could even reconnect if you for some reason replace the wifi module.
@bearer said in Wifi 2 SPI Timeout:
Leaving your network password on the SD card is a security risk. Don't do it.
@dc42 said in Wifi 2 SPI Timeout:
In fact this is the only reason it occurred to me to remove from config.g. If that data were not somewhat sensitive I would have left it and never found the solution.
A oneshot.g or something could work though - read once and deleted by the firmware. Or just decline to provide the m587 at all and let users find the command.
I'm sure you're more than capable of doing the right thing for rrf on this minor issue. Thanks for looking into it!
