Duet 2 meastro 2 Z motor problem
  • I moved this to a new topic from Duet 2 maestro problems
    I did get the x and y moving good and homing good now.. did have a wiring problem
    but still having a Z problem there moving real slow, and it looks like they are moving in the opposite direction of each other..
    I am trying to use E1 for the second Z motor and Z or the first Z motor..
    here is my config again, from reading different messages it seems like I have to use E3
    for the motor mapping and was also told to used E1 any help here please..
    ; generated by RepRapFirmware Configuration Tool v2 on Tue Jul 02 2019 13:29:03 GMT-0400 (Eastern Daylight Time)
    M550 P"mycartiesan" ; Set machine name
    M552 S1 ; Enable network
    M586 P0 S1 ; Enable HTTP
    M586 P1 S0 ; Disable FTP
    M586 P2 S0 ; Disable Telnet
    M569 P0 S0 ; Physical drive 0 goes forwards
    M569 P1 S0 ; Physical drive 1 goes forwards
    M569 P2 S0 ; Physical drive 2 goes forwards
    M569 P3 S0 ; Physical drive 3 goes forwards
    M569 P4 S1 ; Physical drive 3 goes forwards
    M350 X32 Y32 Z32 E32 I0 ; Configure microstepping without interpolation
    M92 X200.00 Y200.00 Z200.00 E420.00 ; Set steps per mm
    M566 X900.00 Y900.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
    M203 X3000.00 Y3000.00 Z180.00 E1200.00 ; Set maximum speeds (mm/min)
    M201 X500.00 Y500.00 Z20.00 E250.00 ; Set accelerations (mm/s^2)
    M906 X400.00 Y400.00 Z400.00 E400.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M564 H0
    M84 S30 ; Set idle timeout
    ;Dual Z
    M584 X0 Y1 Z2:4 E3 ; two Z motors connected to driver outputs Z and E1
    M671 X-20:330 Y0:0 S0.5 ; leadscrews at left and right of X axis
    M208 X-5:325 Y0:325 ; X carriage moves from -5 to 205, Y bed goes from 0 to 200
    M208 X330 Y330 Z330 S0 ; Set axis maxima
    M574 X1 Y1 Z1 S1 ; Set active high endstops
    M558 P5 I1 R0.4 H5 F1200 T6000 ; Set Z probe type to effector and the dive height + speeds
    G31 P500 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
    M557 X15:300 Y15:300 S20 ; Define mesh grid
    M305 P0 T97700 B3950 R2200 ; Set thermistor + ADC parameters for heater 0
    M305 P1 T100000 B4725 C7.060000e-8 R2200 ; Set thermistor + ADC parameters for heater 1
    M106 P0 S0 I0 F500 H1 T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M563 P0 D0 H1 ; Define tool 0
    Thanks gary
  • @gorf26 said in Duet 2 meastro 2 Z motor problem:
    why would you not enable interpolation?
    https://duet3d.dozuki.com/Wiki/Gcode#Section_M584_Set_drive_mapping
    you ignored the section about the order
    Z200 is most likely wrong and the reason why your z axis is moving so slow.
    If you have a 4 start T8 leadscrew, you need Z800
  • Thanks think I have the 2 motors working ok and the x and y now
    I have one issue I thought I had it setup to use the probe for homing
    that doesn't seem to be working..
    I do have a home switch on the z also that is working but not the probe as a home switch..
    so I must be missing something there also..
    Ok thanks M92 go's after M584 from what I am reading
    also when I home x or y the Z move down a few mm then the x or y homes and the z moves back up a few mm is this normal?.
    Thanks gary
    dont use switch + probe. it just makes it more complicated.
    yes its the default for files generated from the configurator.
  • @veti
    so I am assuming now I remove the Z1
    from M574 X1 Y1 Z1 S1
    I modified the homeall and homes
    and added the G30
    Haven't test but will tomorrow..
    Thanks
    you change it by adding
  • @veti
    Thanks that worked OK do I need to set G92 Z0 also
    also it looks like my extruder is set correct but I get no movement
    I sent a g302 p1 first but no motors
    getting the message attempting to extrude with no tool selected..
    I have tried g01 e100 t0 but on luck..
    So guess I have something misconfigured again..
    It does look like the E0 endstop is on yes..
    could that be the problem..
    Gary
  • add this to the end of your config.g
    T0 ; Select first tool
    no that makes no sense. what kind of lead screw do you have?
  • its one I had laying around if I remember right its a 3/8 - 12
    I have the z motors moving haven't checked if they are moving the right distance yet but they are moving together...
    I did get the probe to work for z home also, but I don't think it set the bed to z0
    my main problem right now is no extruder movement even with a m302 p1
    if I check the status it shows that the E0 switch is triggered..
    I assume that's my problem I just don't see anything in the config that bad
    but I still learning..
    Gary
    well guessing is not going to cut it here. you need to know this exactly to calculate the steps per mm or you wont be able to print correctly.
  • @veti
    I know that not to worried about the steps per right now I want to get all the functions
    working then I'll fine tune it...
    and right now the extruder motor isn't moving, and don't see any reason why in the config.
  • what the output in the console if you put in G0 E1?
  • Thanks I got it work, was a typo..
    So now I will calibrate it..
