    Best stepper motors?
    • gtaman
      gtaman last edited by gtaman
      Hello, I'm looking for some good stepper motors to pair with my duet now that I can see the limitations of my Anet steppers in my prints. I'm guessing I want something that has a 0.9 degree step angle, with as much power handling capability as possible.
      These look good for my X and Y axis:
      https://spool3d.ca/nema17-43n-cm-high-torque-stepper-motor/
      and a pair of these would be nice for the Z axis:
      https://spool3d.ca/nema17-stepper-motor-with-attached-lead-screw-40mm/
      My question is, why does the Z axis motor only have a step angle of 1.8 and not 0.9? would I be better off getting a 0.9 degree motor with a coupler??
      also, I saw these:
      https://spool3d.ca/mks-base-servo42-closed-loop-stepper-motor/
      Are they compatible with the duet? I'm guessing no since it doesn't have removable drivers? I'm guessing the duet drivers are better anyways???
      A Former User 1 Reply Last reply Reply Quote 0
      • A Former User
        A Former User @gtaman last edited by A Former User
        @gtaman said in Best stepper motors?:
        T8 with 2mm pitch and 1.8 degrees step &16 microsteps = 360 / 1.8 * 16 / 2 = 1600 steps/mm
        Plenty resolution I'd say. 0.9 degree steps would double the steps/mm and halve the max speed.
        • zapta
          zapta last edited by
          @bearer said in Best stepper motors?:
          T8 with 2mm pitch ...
          The lead is 8mm.
          • Veti
            Veti last edited by
            have a look at the steppers recommended from this build.
            https://www.thingiverse.com/thing:3382718
            • wilriker
              wilriker Moderator last edited by
              Wantai 42BYGHM810 & 42BYGHW811 are two steppers that max out what the Duet is capable of. One is a 1.8° the other is a 0.9° stepper.
              I personally use the 1.8° ones and I am quite happy.
              gtaman 1 Reply Last reply Reply Quote 0
              • gtaman
                gtaman @wilriker last edited by gtaman
                @wilriker Those seem interesting. They're a bit beefier current wise than the e3d ones. How did you find these? Also, Do you know anything about Moon's steppers? Why are they so expensive? I was reading that they were a slight upgrade for the Prussa i3, which would make them a pretty big upgrade from my Anet steppers. There must be something I'm missing in terms of why the Moons' motors are so expensive.
                Edit:I see they've been talked about a bunch on these forums. I still don't get why the Moons' steppers are so expensive though 😕
                wilriker 1 Reply Last reply Reply Quote 0
                • wilriker
                  wilriker Moderator @gtaman last edited by
                  @gtaman I don't know anything about Moon's steppers so I can't help you on that one.
                  As you already found out the Wantai steppers have been mentioned here in several occasions and that's how I got to them. I run them at only 1300mA for X and Y and with my (now no longer used) Anet 12V PSU they were happily throwing X and Y around at 250mm/s.
