    Unknown error status code
    • grizewald
      grizewald last edited by
      I just finished a successful print and was doing some testing. I've just created a new height map and was testing repeated bed levelling probes. I wanted to check if mesh compensation was in use, so I fired off an M122.
      In the report, the error status is 24.
      4 would appear to be "output buffer starvation", but I don't find 2 in the wiki.
      There's a few other interesting things in the report, so I've pasted the whole report below:
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet WiFi 1.02 or later
      Board ID: 08DGM-917NK-F2MS4-7JTD0-3S86S-KYTND
      Used output buffers: 3 of 24 (14 max)
      Static ram: 25680
      Dynamic ram: 93716 of which 344 recycled
      Exception stack ram used: 540
      Never used ram: 10792
      Tasks: NETWORK(ready,524) HEAT(blocked,1236) MAIN(running,1568) IDLE(ready,160)
      Owned mutexes:
      Last reset 02:05:28 ago, cause: power up
      Last software reset at 2019-08-04 19:40, reason: User, spinning module GCodes, available RAM 10792 bytes (slot 1)
      Error status: 24
      Free file entries: 10
      SD card longest block write time: 391.3ms, max retries 0
      MCU temperature: min 21.2, current 38.1, max 40.0
      Supply voltage: min 23.9, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: standstill, SG min/max 0/141
      Driver 1: standstill, SG min/max 0/150
      Driver 2: standstill, SG min/max 0/48
      Driver 3: standstill, SG min/max 0/1023
      Driver 4: standstill, SG min/max 0/55
      Date/time: 2019-08-08 17:45:19
      Slowest loop: 113.63ms; fastest: 0.07ms
      Hiccups: 6, FreeDm: 169, MinFreeDm: 105, MaxWait: 1041342ms
      Bed compensation in use: mesh, comp offset -0.069
      === DDARing ===
      Scheduled moves: 747, completed moves: 747, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
      Heater 0 is on, I-accum = 0.2
      Heater 1 is on, I-accum = 0.2
      Segments left: 0
      Stack records: 3 allocated, 0 in use
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 393.69ms; fastest: 0.00ms
      HTTP sessions: 1 of 8
      - WiFi -
      Network state is running
      WiFi firmware version 1.23
      WiFi MAC address 84:f3:eb:42:a3:23
      WiFi Vcc 3.45, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 25512
      WiFi IP address 192.168.1.29
      WiFi signal strength -47dBm, reconnections 0, sleep mode modem
      I'm assuming the errors come from my print. The parts look OK - they were three copies of an IN14 Nixie tube spacer printed at 0.1mm layer height. Print speed was 60mm/s with 100mm/s travel. The printer is a large CoreXY.
      • grizewald
        After looking through the source code for the firmware, I don't find 0x20 in the ErrorCode enumeration either.
        So why would errorCodeBits ever get that bit set? @dc42
        Also, any ideas what would cause the output buffer starvation? The model being printed is tiny, but it does include lots of circles. Then again, I'm only printing it at 60mm/s and the circles don't have that many facets. I've attached the model for reference.
        0_1565365509322_base.stl
