Delta Smart Effector hotend temperature fluctuations
This is in the 2-3 minutes right after last forum post. It looks like it is related to the nozzle tip ramming into some filament blobs (caused by imperfect filament flow, or variable filament quality)
I reset those H1 faults but it seems that every print session could be done only by manual human intervention every 5-10 minutes or so. Unless there is a way to lower the sensitivity which consists of the Delta Smart Effector board + the PT100 daughterboard + the PT100 sensor.
I am sure that the Duet firmware was designed to aid me to face the fire hazard -- who knows why a heater fault may occur ? -- but I see an additional reason for which all those "alien" heater H1 faults appear: the filament may not cost a ton of gold per spool. Which is perfectly the situation of 99.99 % of of the customers which buy the Duet board and the Delta Smart Effector.
That is why I need a way to tell the Duet board to ignore H1 heater faults unless those faults are 50% of the requested printing temperature, or worse.
Is there such a method to lower that PT100 chain sensitivity?
Thanks
Hello
There were no solar flares yesterday. The problem is that the nozzle of the Delta Smart Effector hits various micro-obstacles on the printed object. Since the existence of those micro-obstacles cannot be avoided, we need to "deafen" the PT100.
I believe the sensitivity of the PT100 mechanism can be lowered with one or two ceramic capacitors. However I am not sure how it would be best:
a) One single capacitor between the two middle pins of the four pins at the PT100 daughterboard level ? (My PT100 sensor is 2-wire)
b) One single capacitor between the two PT100 pins on the Delta Smart Effector at the Delta Smart Effector pcb level ?
c) Two capacitors on the PT100 daughterboard: first capacitor between one middle PT100 pin and the daughterboard's GND, and the second capacitor between the other middle PT100 pin and the daughterboard's GND ?
Please can you tell which variant you think would be best, and if the 10 nF capacity is OK for the variant thought as best ?
Thank you
@mihaitintea I have been using the pt100/smart effector combination without problems. Following an earlier suggestion, I use stranded cat6 cable - two pairs for the pt100 and two pairs for the z probe. I did find the small connectors on the daughterboard a bit tricky (eyes not what they used to be) - maybe worth checking.
@mihaitintea said in Delta Smart Effector hotend temperature fluctuations:
Hello
Thank you
I have already recommended option C on this forum. The recommended value is 100nF. I have verified that this fixes problems caused by noise being picked up from stepper motor cables etc. There is already a capacitor connected between the two middle pins.
Two other possibilities:
- Grounding the hot end metalwork (so that the case of the PT100 sensor is grounded) may help.
- If it is mechanical shock to the sensor that causes the fluctuations, the PT100 sensor may be faulty.
@dc42 Hello
I applied option C, I just hope I identified correctly the GND on the PT100 daughterboard, please can you confirm from the picture below ?
Thank you
