    Extruding while homing axis
    155
    • Ntrack
      Ntrack last edited by
      Hello. How can I extrude/retract while I am moving one axis towards it's endstop?
      I have relative extrusion enabled.
      G91 G1 S1 V-600 E-600 F3000 is moving only the V axis.
      • A Former User
        A Former User last edited by
        Maybe look at the status for the enstop of E axis? S1 would apply to both V and E.
        (and for futureproofing I'd go with H1 instead of S1 as it has mixed meanings depending on mode FFM/laser)
        M119prints out the status of the endstops.
        • Ntrack
          The sensor triggers, I've just assigned another A axis on the extruder drive. Now V and A axis move together but A doesn't stop when V triggers the endstop. V stops but A just continue to finnish the movement.
          A Former User 1 Reply Last reply Reply Quote 0
          • A Former User
            A Former User @Ntrack last edited by
            @ntrack said in Extruding while homing axis:
            That is the expected behaviour. Someone else will have to chime in on how to reconfigure the two motors to move as a single axis to achieve what you want.
            • Ntrack
              Will I have to wire the endstops to the E pins as well as V axis? I already have two endstops on V
              • A Former User
                That could work if its a possibility. G1 H1 Vn An will move both V and A until they hit their respective enstops or have moved n units.
                Alternatively you could configure V axis to move two motors prior to the move in question, then both would stop when V endstop is hit. But I'm not too familiar with how that works.
                Ntrack 1 Reply Last reply Reply Quote 0
                • Ntrack
                  Ntrack @Guest last edited by
                  Two motors with different steps/mm is well above my level 🙂
                  I’ll wire the endstops to the E pin and V , I will call the A axis whenever I want that motor to stop to trigger. Hopefully it works , I’ve seen something similar on the forum.
                  • Ntrack
                    Ntrack last edited by Ntrack
                    I can't make it work with the endstop connected to V and E pins . First I tried modifying config.g , adding E3 A3 in M584 and configure microstepping and steps/mm the same as the E axis and I've had the same behaviour as before. V axis would stop when it hits the endstop while A axis would continue the move.
                    Then I tried to swap the assignments of the drivers on the fly with the intention to revert it after the endstop is triggered.
                    M584 E9 A3
                    M350 A16 E16 I0
                    M92 E946 A946			   ; Set steps per mm
                    M566 E240 A240                            ; Set maximum instantaneous speed changes (mm/min)
                    M203 E7200 A7200                     ; Set maximum speeds (mm/min)
                    M201 X2500 Y2500 Z200 E5000 U500 V2000 W2000                      ; Set accelerations (mm/s^2)
                    M204 P1250 T2500				   ; Set acceleration When printing
                    M906 E950 A950 I44                     ; Set motor currents (mA) and motor idle factor in per cent
                    M84 S30                                          ; Set idle timeout
                    M208 A-1000 S1
                    M208 A1000 S0
                    G92 A0
                    M574 V2 A2 S0 			; set V axis max endstop to switched low
                    M400
                    G1 V100 A100 H1 F500	        ; fast feed filament into extruder
                    M400
                    G92 V0 A0			; force V to 0mm
                    Basically configuring an entire new axis and moving the extruder on a unpopulated stepper. This results in the same behaviour as above, v axis stops at the endstop while A axis finishes the move.
                    I also found this. Moving the extruder on another stepper on the duex5 would help? Are those treated as extruders as well?
                    • Ntrack
                      Yeah, I might have the answer there. According to that A axis endstop should work if connected to E3.
                      A axis is controlled by E3 endstop.Problem solved.
