    [Help] CR10S5 RepRap configuration
    • rlucho
      rlucho last edited by
      Hi! I'm new to the 3d printer and Duet world, I own a CR10S5 and I already installed a Duet 2 Wifi, so I wanted to know if anyone with a CR10S5 and Duet 2 Wifi can share with me their config file, that way I will have a good base to start tweking the config of my machine. Thanks in advance! Have a good day!
      • NitroFreak
        NitroFreak last edited by
        did you try the reprap config tool? It´s linked in the Dozuki
        https://duet3d.dozuki.com/Wiki/Step_by_step_guide
        • Veti
          Veti last edited by
          take the base values from the marlin configuration.h like steps per mm, acceleration, etc. that should get you started in the
          https://configurator.reprapfirmware.org/
            The CR10 and Ender 3 are actually quite similar, so perhaps this series of guides will be helpful.
            https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+1:+Wiring/37
