    Bed heater PID
    • Deler
      Deler last edited by
      I tried to find the answer to my question on the forum, but no luck.
      I have silicon heater 220V controlled by SSR. Currently, it is working in Bang-bang mode. I want to use PID mode.
      I have checked https://duet3d.dozuki.com/Wiki/Choosing_a_bed_heater#Section_Bed_heater_driven_using_a_Solid_State_Relay but it is not clear for me how to set PWM frequency to 10Hz.
      can someone help me and tell me what parameters I need to use with M307
      • deckingman
        deckingman @Deler last edited by
        @deler As long as you use B0 to disable bang bang mode, then the default PWM frequency for the bed heater (H0) is 10Hz so you don''t need specify. But for future reference, or if you use a heater other than H0, then use F10. It is documented here https://duet3d.dozuki.com/Wiki/Gcode#Section_M307_Set_or_report_heating_process_parameters
        Deler 2 Replies Last reply Reply Quote 0
        • Deler
          Deler @deckingman last edited by
          @deckingman Thank you. it is more clear now
          • Deler
            Deler @deckingman last edited by Deler
            Another question came to my mind, do I need to do any PID tuning? if yes how can I do that?
              dc42 administrators @Deler last edited by
              @deler said in Bed heater PID:
              Yes. Look up M303 on that same GCode wiki page.
              Deler 1 Reply Last reply Reply Quote 0
              • Deler
                Deler @dc42 last edited by
                @dc42 said in Bed heater PID:
                after the tunning, I got the following results
                Heater 0 model: gain 207.8, time constant 143.4, dead time 4.4, max PWM 1.00, calibration voltage 12.2, mode PID, inverted no, frequency default
                also, I got a warning: heater 0 appears to be over-powered. if left on at full power, its temperature is predicted to reach 232c.
                is it normal?
                • deckingman
                  is it normal?
                  Yes. Head the warning and don't leave the printer unattended for lengthy periods of time. In the unlikely event that a Mosfet or your SSR failed closed, then your bed could reach a temperature of 232 deg C.
                  If you are concerened, then you can either use a lower powered heater or fit a thermal cut out switch.
