    Steppers close to Duet board
    • bartolomeusundefined
      bartolomeus
      Is it ok to have the stepper motors right beside the Duet board, or will I run into some kind of interference?
      • Vetiundefined
        Veti
        the pt100 sensor is prone to interference. so keep those wires away from any other wires.
          Placing stepper motors close to the Duet shouldn't cause any problem.
            bartolomeus
            Thanks! Now I feel safe to shorten the stepper motor wiring.
              droftarts administrators
              The Fisher delta I have is pretty much the same with no problems, though it uses a thermistor rather than PT100:
