    Unintentional axis movement
    357
    • kerembyl
      kerembyl last edited by kerembyl
      In some cases Y axis is moving certain amount unintentionally. I use three-point manual bed leveling and nozzle travels 3 points respectively.
      Here the coordinates of those points are:
      [“X30 Y30”, “X270 Y30", “X170 Y300”]
      First move: G1 X30 Y30 (No problem)
      Second move: G1 X270 Y30 (X goes to 270 and Y supposed to stay still but it moves anyway. It moves approximately 3-4 milimeters in positive direction.)
      All movements are done in absolute cartesian coordinate system.
      Hardware: Duet2 Wifi
      Firmware: 2.03beta3
      What would cause this?
      Thanks in advance.
      My configuration:
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      M208 X330 Y330 Z330 S0 ; Set axis maxima
      M574 S0 ; Define active low and unused microswitches
      M574 X1 Y1 Z0 S1 ; Define active high microswitches
      M558 P5 X0 Y0 Z1 H10 F120 T6000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
      G31 X0 Y0 Z0 P10
      M557 X30:310 Y0:250 S50 ; Define mesh grid
      M581 E0 S0 T3 C0
      M581 E0 S1 T4 C0
      G29 S2
      M350 X256 Y256 Z256 E256 I0 ; Configure microstepping without interpolation
      M92 X1280 Y1280 Z10240 E2544 ; Set steps per mm
      M566 X900 Y900 Z10 E120 ; Set maximum instantaneous speed changes (mm/min)
      M203 X18000 Y18000 Z1000 E1200 ; Set maximum speeds (mm/min)
      M201 X1500 Y1500 Z100 E2000 ; Set accelerations (mm/s^2)
      M906 X1700 Y1700 Z1800 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M143 S380 ; Set maximum heater temperature to 380C
      M305 P0 T100000 B4623 C9.264103e-8 R4193 ; Set thermistor + ADC parameters for heater 0
      ; There are two types of thermistors in the field on P1. Setting it via hw_version check
      M305 P2 T100000 B4623 C9.264103e-8 R4193
      M307 H3 A-1 C-1 D-1
      M141 H2
      M563 P0 D0 H1 ; Define tool 0
      M550 Pmachina ; Set machine name
      M551 Ppass ; Set password
      M552 S0 ; Enable network
      M586 P0 S1 ; Enable HTTP
      M586 P1 S1 R21 T0 ; Enable FTP
      M586 P2 S0 ; Disable Telnet
      M106 P0 S1 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H2 T50 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S1 I0 F500 H2 T50 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 S0
      M501
      • Veti
        Veti last edited by
        lets start of with the first thing. there is a M208 before the M584
        See
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M584_Set_drive_mapping
        Order dependence
        M584 must come earlier in config.g than any M350 and M906 commands. If it creates new axes, it must also be earlier than any M92, M201, M203, M208, M350, M566, M574 , M667 and M669 commands.
        • Veti
          Veti last edited by
          @kerembyl said in Unintentional axis movement:
          M501 ; Check config override file
          also it makes sense that this should be the last command in your config. not one of the first.
          • kerembyl
            @veti said in Unintentional axis movement:
            I fixed the things you mentioned, problem is still there. Thank you for correction though.
            • Veti
              Veti last edited by
              if you move back to G1 X30 Y30. does it return to the same place as the original G1 X30 Y30 ?
              • droftarts
                droftarts Moderator last edited by
                Is any axis compensation applied? I'm thinking more of the M556 orthogonality type. Possibly in homeall.g or bed.g?
                kerembyl 1 Reply Last reply Reply Quote 0
                • kerembyl
                  kerembyl @droftarts last edited by
                  @droftarts neither both of them have M556. There is no axis compensation.
                  @Veti Error is not consistent so i could not experiment that.
                  • Veti
                    Veti last edited by
                    can you post a picture of your printer?
                    • kerembyl
                      kerembyl @Veti last edited by
                      @veti If you tell me what exactly do you want to see i can help you better. Because product is commercial and under development.
                      • Veti
                        Veti last edited by
                        is the movement for x and y independent?
                        what do the u and v axis do?
                        • kerembyl
                          kerembyl @Veti last edited by kerembyl
                          @veti In order to prevent confusion because of U and V axis, i edited first post and submitted simpler config file. This belongs to another device which runs on same hardware and firmware and problem still exists. What i mean is it is not relevant to creating additional axes.
                          X and Y axes are independent for sure. They are driven by seperate stepper with no mapping applied to each other.
                          • Veti
                            Veti last edited by
                            does the y stepper motor actually move when doing the move from 30 to 270?
                            • kerembyl
                              @veti yes from x30 to x270 it moves.
                              • Veti
                                Veti last edited by
                                and you ruled out any mechanical issue? like moving the head manually when the duet is off to see if the movement happens as well?
                                without axis compensation there should be no movement on the y motor.
                                can you also post the config-overwrite
                                • kerembyl
                                  I ruled out all mechanical issues, all of our devices have this problem.
                                  config-overwrite.g contains only PID and BL Touch parameters.
                                  Oddly enough, this is not happening while printing. Because dimensions are true.
                                  ; Heater model parameters
                                  M307 H0 A90.0 C700.0 D10.0 S1.00 B1
                                  M307 H1 A435.6 C268.1 D12.2 S0.27 B0
                                  M307 H2 A340.0 C140.0 D5.5 S1.00 B0
                                  M307 H4 A340.0 C140.0 D5.5 S1.00 B0
                                  M307 H5 A340.0 C140.0 D5.5 S1.00 B0
                                  M307 H6 A340.0 C140.0 D5.5 S1.00 B0
                                  M307 H7 A340.0 C140.0 D5.5 S1.00 B0
                                  ; Z probe parameters
                                  G31 T1 P10 X0.0 Y0.0 Z1.50
                                  G31 T3 P500 X0.0 Y0.0 Z0.70
                                  G31 T4 P500 X0.0 Y0.0 Z0.00
                                  • MrsDelish
                                    MrsDelish last edited by
                                    This movement only happens when you probe your bed? If that is the case there is probably a probe offset(G31) in Y set somewhere, since the i.e:
                                    G30 X100 Y100 uses position of probe(nominal tool holder position & probe offset) , where as
                                    G1 X100 Y100 uses active tool position(nominal tool holder position & tool offset).
                                    Check your config.g, homeX/Z/Y.g and Bed.g for any G31 with a XY value or G10 tool offset in XY.
                                    • Veti
                                      Veti last edited by
                                      i dont see anything in the config that would explain that.
                                      just to rule out any firmware problem please update to the stable 2.03
                                      • kerembyl
                                        kerembyl @MrsDelish last edited by
                                        @mrsdelish It also happens on a device which employs manual bed leveling. (without probe)
                                        • kerembyl
                                          @dc42 Do you have any idea about that?
                                            dc42 administrators @kerembyl last edited by
                                            Firmware: 2.03beta3
                                            Beta versions of firmware are not supported once a later beta or (as in this case) the corresponding full release has been published. So you should upgrade to 2.03 (final release) or 2.04RC1 and test again.
                                            kerembyl 2 Replies Last reply Reply Quote 0
                                            • kerembyl
                                              kerembyl @dc42 last edited by
                                              @dc42 I just have upgraded to 2.04RC1 and the problem still occurs
                                              • kerembyl
                                                I experience something similar to that on my IDEX configuration. Steps to reproduce this problem: (all steps done via web interface)
                                                Step 1: Home All
                                                Step 2: Select Tool 1 (U axis)
                                                Step 3: Move Y axis 100 mm in positive direction
                                                Step 4: Move U axis 15 (or any value) in negative direction
                                                Step 5: Move Y axis 1 mm in positive direction
                                                When step 5 is performed Y axis supposed to move 1mm but the U axis moves back to the home position unintentionally instead.
