    Duet 3 0-10v support?
    • Perseveranzeundefined
      Perseveranze
      I was looking through all the information for the new Duet 3 board and I didnt see if it carries any 0-10v signal support. Is there any support for this feature or will there be in the future? I know a few people have asked in the forums about something like this for CNC spindle control.
      • elmoretundefined
        elmoret
        It’s pretty easy to convert PWM to 0-10v if needed.
        Perseveranzeundefined 1 Reply Last reply Reply Quote 0
          Perseveranze @elmoret
          @elmoret I've been trying but my Fan PWM ports will not respond to any command, all they display is the V_IN. I'm not too sure what else to do in my config.g file to grt them to work properly. You have any ideas?
          • elmoretundefined
            elmoret
            That’s all they’re going to display unless your meter can read PWM.
            https://www.google.com/search?source=hp&ei=vd1jXcnxGsr45gL924e4Cw&q=convert+pwm+to+analog&oq=convert+pwm+to+analog&gs_l=mobile-gws-wiz-hp.3..0l3j0i22i30l4j33i299.1598.7403..7765...0.0..0.496.2620.14j4j2j0j1......0....1.......0..0i131j46i131.o191G2XvMNg
