    A Repeating Artifact
    1.6k
    • B0M0A0Kundefined
      B0M0A0K @mrehorstdmd
      @mrehorstdmd OK, I took your advice and focused on using calibration cubes to set retraction first. Here are the results and it's clear that the farther away from 1mm the worse it gets.
      One strange artifact that appears on all these cubes is the "tail". It typically appears on the first cube and varying lengths in between but always presents again on the last cube.
      Any thoughts on what might be causing this?
      No fate but what we make ....
      • B0M0A0Kundefined
        B0M0A0K
        .. And it doesn't actually help if I don't tell you the settings I am using in Cura. Sorry, here are my Cura settings.
        Resolution: 0.2mm
        Print Temp: 200 and later 195
        Print Temp Initial Layer: 200 and later 195
        Initial print temp: 190 and later 185
        Build Plate Temp: 60
        Flow: 100%
        Retraction enabled
        Retraction Distance: 1mm
        Retraction Speed: 25
        Print Speed: 60
        Travel Speed: 120
        Initial Layer Speed: 30.0
        Cooling Enabled
        FAN Speed: 100
        FAN Regular Speed: 100
        FAN Max Speed: 100
        Support: No
        Build Plate Adhesion: Skirt
        Skirt Width: 3
        Print Sequence: All At Once
        • B0M0A0Kundefined
          B0M0A0K
          Actually, I kept increasing the retraction and eventually the "tail" disappeared. I needed to increase retraction to 1.3mm before this happened.
