    Hotend temperature fluctuations
    • NitroFreak
      NitroFreak last edited by
      I wanted to know how to get rid of these temperature fluctuations?
      They are +1-0.5 degrees for the red one and +2.5-1 °C for the green one.
      The red one is my main with a PT100 tuned for 420C and the blue one a thermistor tuned for 300C.
      I read somewhere that when autotune does not get rid of these fluctuations, you have to increase the dead time by 30%. However i haven´t noticed a change.
      Any idea?
      Max
      • Urban
        Urban last edited by
        Maybe you could try the PID settings instead, these should be listed when you autotune. To me it looks like the P part is to high, so try cutting it to half. I would also tune at the temperature that you intend to keep, so 300 in this case.
        NitroFreak 1 Reply Last reply Reply Quote 0
        • NitroFreak
          NitroFreak @Urban last edited by
          @urban said in Hotend temperature fluctuations:
          I know it would be better, but i print with PPSU at 395°C regularly.
          What do you mean by PID? how do you change the ADC values from the autotune to PID?
          • Urban
            The M301 command. When you do the autotune the PID parameters are printed at the end of the tuning.
            Hmm.. I also remember that I forgot to insert the ADC values in the config.g once and they disappeared somehow. Maybe that happened to you as well?
            PID is the way you normally control a temperature. This is a good site to explain it:
            http://brettbeauregard.com/blog/2011/04/improving-the-beginners-pid-introduction/
