    Bed Leveling compensates to 1.5~3.5 mm below printing surface
    932
    • worekarolisundefined
      worekarolis
      I just some upgrades to my delta printer, newest firmware, cooling fan and indirect laser filament sensor.
      After updates head rams hard into printing bed. Apparently it though that surface is way below the actual one. So I thought it had to do something with filament sensor so I have disconnected and disabled it in cfg.
      That have not changed anything, so I have removed fan too 🙂 well who knows...
      Still same thing. After examining I figured that it always compensates to 1.5~3.5 mm below the surface after restart. It seems that it triggers on right time, exactly when it bumps on surface.
      Things get stranger if I don't restart the printer.
      I have no idea why.
      config-override.g
      ; config-override.g file generated in response to M500 at 2019-05-14 10:48
      ; Delta parameters
      M665 L400.320 R164.355 H518.72 B165.0 X0.000 Y0.000 Z0.000
      M666 X-0.017 Y0.088 Z-0.071 A0.00 B0.00
      ; Heater model parameters
      M307 H0 A191.7 C568.8 D3.2 S1.00 V24.5 B0
      M307 H1 A944.2 C325.2 D6.4 S1.00 V24.0 B0
      M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      M307 H3 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      M307 H6 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      M307 H7 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      G10 L2 P1 X0.00 Y0.00 Z0.00
      G10 L2 P2 X0.00 Y0.00 Z0.00
      G10 L2 P3 X0.00 Y0.00 Z0.00
      G10 L2 P4 X0.00 Y0.00 Z0.00
      G10 L2 P5 X0.00 Y0.00 Z0.00
      G10 L2 P6 X0.00 Y0.00 Z0.00
      G10 L2 P7 X0.00 Y0.00 Z0.00
      G10 L2 P8 X0.00 Y0.00 Z0.00
      G10 L2 P9 X0.00 Y0.00 Z0.00
      bed.g
      ; called to perform automatic delta calibration via G32
      ; generated by RepRapFirmware Configuration Tool v2 on Tue Feb 19 2019 21:54:36 GMT-0500 (Eastern Standard Time)
      G28  ; home all towers
      G30 P0 X0.00 Y160.00 Z-99999 H0
      G30 P1 X80.00 Y138.56 Z-99999 H0
      G30 P2 X138.56 Y80.00 Z-99999 H0
      G30 P3 X160.00 Y0.00 Z-99999 H0
      G30 P4 X138.56 Y-80.00 Z-99999 H0
      G30 P5 X80.00 Y-138.56 Z-99999 H0
      G30 P6 X0.00 Y-160.00 Z-99999 H0
      G30 P7 X-80.00 Y-138.56 Z-99999 H0
      G30 P8 X-138.56 Y-80.00 Z-99999 H0
      G30 P9 X-160.00 Y-0.00 Z-99999 H0
      G30 P10 X-138.56 Y80.00 Z-99999 H0
      G30 P11 X-80.00 Y138.56 Z-99999 H0
      G30 P12 X0.00 Y80.00 Z-99999 H0
      G30 P13 X69.28 Y-40.00 Z-99999 H0
      G30 P14 X-69.28 Y-40.00 Z-99999 H0
      G30 P15 X0 Y0 Z-99999 S7
      homedelta.g
      G91                       ; relative positioning
      G1 S1 X650 Y650 Z650 F3800 ; move all towers to the high end stopping at the endstops (first pass)
      G1 X-5 Y-5 Z-5 F1800 S2   ; go down a few mm
      G1 S1 X10 Y10 Z10 F360    ; move all towers up once more (second pass)
      G1 Z-5 F6000              ; move down a few mm so that the nozzle can be centred
      G90                       ; absolute positioning
      G1 X0 Y0 F6000            ; move X+Y to the centre
      config.g
      M558 P8 R0.4 F1200 H5 T6000       ; Set Z probe type to effector and the dive height + speeds
      G31 P100 X0 Y0 Z0.15              ; Set Z probe trigger value, offset and trigger height
      M672 S105:80:175 		  ; Set Z probe sensitivity to 90
      M557 R165 S20                     ; Define mesh grid"
      Did I forget something?
      • milangupta1undefined
        milangupta1
        I was trouble shooting a similar issue although on a cartesian printer. Turned out to be the trigger height set incorrectly (-ve instead of +ve).
        G31 in config.g. Should this be a positive value ? Also, M666 in bed.cfg ?
        milangupta1undefined 1 Reply Last reply Reply Quote 0
          milangupta1 @milangupta1
          @milangupta1 Also, where is G92 in homedelta.g ? Shouldn't that be set as the new x and y home positions before you move back to absolute positioning ..
          worekarolisundefined 2 Replies Last reply Reply Quote 0
          • Vetiundefined
            Veti
            after your changes did you recalibrate your delta and save the new values in the M665 and M666 command?
            worekarolisundefined 1 Reply Last reply Reply Quote 0
              worekarolis @Veti
              @veti
              I haven't done any new changes as everything was working perfectly. Will have to go though that later today I guess.
              • Vetiundefined
                Veti
                @worekarolis said in Bed Leveling compensates to 1.5~3.5 mm below printing surface:
                you wrote that you did upgrades to your delta.
                  worekarolis @Veti
                  @veti
                  I mean I have not done changes to configuration or structure. Just added a fan and filament sensor
                    worekarolis @milangupta1
                    This post is deleted!
                      @milangupta1
                      There is G90 in there so no need for G92 as much as I understand
                      • Vetiundefined
                        Veti
                        as milangupta1 said. your bed config should look something like this (adjust for your bed)
                        and the M665 and M666 should be in the config.g
                        ; bed.g
                        ; generated by RepRapFirmware Configuration Tool v2.0.0 on Thu Aug 29 2019 14:53:59 GMT+0200 (Mitteleuropäische Sommerzeit)
                        ; Probe the bed at 12 peripheral and 0 halfway points, and perform 6-factor auto compensation
                        ; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g.
                        G30 P0 X0 Y84.9 H0 Z-99999
                        G30 P1 X42.45 Y73.53 H0 Z-99999
                        G30 P2 X73.53 Y42.45 H0 Z-99999
                        G30 P3 X84.9 Y0 H0 Z-99999
                        G30 P4 X73.53 Y-42.45 H0 Z-99999
                        G30 P5 X42.45 Y-73.53 H0 Z-99999
                        G30 P6 X0 Y-84.9 H0 Z-99999
                        G30 P7 X-42.45 Y-73.53 H0 Z-99999
                        G30 P8 X-73.53 Y-42.45 H0 Z-99999
                        G30 P9 X-84.9 Y0 H0 Z-99999
                        G30 P10 X-73.53 Y42.45 H0 Z-99999
                        G30 P11 X-42.45 Y73.53 H0 Z-99999
                        G30 P12 X0 Y0 H0 Z-99999 S6
                        ; Use S-1 for measurements only, without calculations. Use S4 for endstop heights and Z-height only. Use S6 for full 6 factors
                        ; If your Z probe has significantly different trigger heights depending on XY position, adjust the H parameters in the G30 commands accordingly. The value of each H parameter should be (trigger height at that XY position) - (trigger height at centre of bed)
                          worekarolis @Veti
                          @veti
                          sorry, I've labeled this incorrectly. M665 and M666 are in the config overide. Correcting post.
                          • Vetiundefined
                            Veti
                            are you using mesh bed compensation?
                            i.e. loading the heightmap somewhere
                              worekarolis @Veti
                              @veti
                              I've used it, but now its disabled.
                                worekarolis @Veti
                                @veti
                                coud this be a problem?
                                G29 S1 ; load a previously-generated height map
                                Vetiundefined 1 Reply Last reply Reply Quote 0
                                • Vetiundefined
                                  Veti @worekarolis
                                  @worekarolis
                                  yes. loading it will change the z=0 based on the values in the heightmap.
                                    worekarolis @Veti
                                    @veti
                                    Removing it haven't changed behavior
                                    • fcwiltundefined
                                      fcwilt
                                      The trigger height setting for your Z-probe might be wrong.
                                      The H parameter to M665 might be wrong.
                                      Either one can result in Z=0 not being the surface of the bed.
                                        worekarolis
                                        After updating to 2.04RC1 (2019-07-14b1) issue is gone.
                                        Many thanks for your help!
