    Switch to Pt-100
    • CarlBosson
      CarlBosson last edited by
      So I changed to a Pt-100 for high temp printing. I can manually enter "M305 P1 X200" and the control will display the correct temp. I would like to make this change permanent. Below is the line from the config.g in settings. I tried M305 P1 X200 B4138 R4700 with no luck. Can someone tell me how to fix this?
      M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
      I would also like to know how to adjust the temp limits for the bed and extruder. I plan to print PEKK so I need to adjust up to 140C on the bed temp and 360C on the extruder.
      • Veti
        Veti last edited by Veti
        @carlbosson said in Switch to Pt-100:
        M305 P1 X200
        just replace the line with exactly that. no B or R value
        for the max value adjust these lines
        CarlBosson 1 Reply Last reply Reply Quote 0
        • CarlBosson
          Sorry adding just "M305 P1 X200" Seems to have done the trick.☺
          • deckingman
            deckingman @CarlBosson last edited by deckingman
            @carlbosson As you have discovered, when using a PT100 you don't need the B and R parameters. Simply replace your existing M305 line with M305 P1 X200.
            The maximum temperature limits are set using M143 https://duet3d.dozuki.com/Wiki/Gcode#Section_M143_Maximum_heater_temperature
            Edit - we must have been typing at the same time so I missed you last post.
            • CarlBosson
              CarlBosson @Veti last edited by
              @veti Thank you, I missed adding the adjustment after S. All seems to be working now! Thanks
