    Z axis movement
    826
    • drthomasw3undefined
      drthomasw3
      I have fitted my Tronxy X5SA with a Duet 2 WiFi. X, Y, Z and extrude work properly( move correct distance in the correct direction). The machine homes properly. But, when I try to print the build plate moves into the print head each layer. G code for the test cube has the Z increasing .2mm each layer.
      • Vetiundefined
        Veti
        are you saying the z moves in the wrong direction during printing? or distance traveled wrong?
        please post your config.g
          drthomasw3
          The wrong direction during printing
          • Vetiundefined
            Veti
            @drthomasw3 said in Z axis movement:
            when you issue a z move in the web ui. does it move in the wrong direction as well?
            if so you need to invert the z motor direction and modify your homing file. you might be homing to max rather than min.
              drthomasw3
              No from the web ui. The input of a positive Z value results in + movement the bed goes down.
              ; homez.g
              ; called to home the Z axis
              ; generated by RepRapFirmware Configuration Tool v2 on Sat Aug 17 2019 17:57:39 GMT-0400 (Eastern Daylight Time)
              G91 ; relative positioning
              G90 ; absolute positioning
              G1 X25 Y25 F6000 ; go to first probe point
                drthomasw3
                Now when I home z I get
                • Vetiundefined
                  Veti
                  still waiting for your config
                    drthomasw3
                    ; generated by RepRapFirmware Configuration Tool v2 on Sat Aug 17 2019 17:57:37 GMT-0400 (Eastern Daylight Time)
                    M667 S1 ; Select CoreXY mode
                    M550 P"My Printer" ; Set machine name
                    M552 S1 ; Enable network
                    M587 S"Bones" P"Gre8Scot ;" I10.9.65.119 J10.9.65.248 K255.255.255.0 ; Configure access point and IP addresses. You can delete this line once connected
                    M586 P0 S1 ; Enable HTTP
                    M586 P1 S0 ; Disable FTP
                    M586 P2 S0 ; Disable Telnet
                    M569 P0 S1 ; Physical drive 0 goes forwards
                    M569 P1 S1 ; Physical drive 1 goes forwards
                    M569 P2 S0 ; Physical drive 2 goes backwards
                    M569 P3 S0 ; Physical drive 3 goes backwards
                    M92 X80.00 Y80.00 Z400.00 E98.00 ; Set steps per mm
                    M566 X600.00 Y600.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
                    M203 X18000.00 Y18000.00 Z180.00 E1500.00 ; Set maximum speeds (mm/min)
                    M201 X3000.00 Y3000.00 Z100.00 E10000.00 ; Set accelerations (mm/s^2)
                    M906 X950.00 Y950.00 Z950.00 E950.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
                    M84 S30 ; Set idle timeout
                    M208 X330 Y330 Z400 S0 ; Set axis maxima
                    M574 X1 Y1 S1 ; Set active high endstops
                    M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
                    M558 P9 H5 F120 T6000 ; Set Z probe type to bltouch and the dive height + speeds
                    G31 P500 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
                    M557 X15:12 Y15:195 S20 ; Define mesh grid
                    M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
                    M563 P0 D0 H1 ; Define tool 0
                    ; Automatic power saving
                    M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run o
                    • Vetiundefined
                      Veti
                      not related but B4138 is wrong for your thermistor.
                      i dont see a reason why it would be moving down before print but up during the print.
                      unless your g codes contain code that would change the configuration at the beginning.
                        drthomasw3
                        Test g code that results in z moving the wrong direction: Did I miss something?
                        G90
                        M82
                        M106 S0
                        M140 S60
                        M190 S60
                        M104 S210 T0
                        M109 S210 T0
                        G28 ; home all axes
                        G1 Z0.2 F3000 ; get ready to prime
                        G92 E0 ; reset extrusion distance
                        G1 X100 E10 F600 ; prime nozzle
                        ; process Process1
                        ; layer 1, Z = 0.105
                        T0
                        G92 E0.0000
                        G1 E-4.0000 F2400
                        ; feature skirt
                        ; tool H0.105 W0.600
                        G1 Z0.105 F1000
                        G1 X135.100 Y137.970 F4800
                        G1 E0.0000 F2400
                        G92 E0.0000
                        G1 X137.970 Y135.100 E0.0957 F1500
                        G1 X162.030 Y135.100 E0.6628
                        G1 X164.900 Y137.970 E0.7585
                        G1 X164.900 Y162.030 E1.3257
                        G1 X162.030 Y164.900 E1.4214
                        G1 X137.970 Y164.900 E1.9885
                        G1 X135.100 Y162.030 E2.0842
                        G1 X135.100 Y137.970 E2.6514
                        G92 E0.0000
                        G1 E-4.0000 F2400
                        G1 X135.700 Y138.219 F4800
                        G1 E0.0000 F2400
                        G92 E0.0000
                        G1 X138.219 Y135.700 E0.0840 F1500
                        G1 X161.781 Y135.700 E0.6394
                        G1 X164.300 Y138.219 E0.7234
                        G1 X164.300 Y161.781 E1.2788
                        G1 X161.781 Y164.300 E1.3628
                        G1 X138.219 Y164.300 E1.9182
                        G1 X135.700 Y161.781 E2.0022
                        G1 X135.700 Y138.219 E2.5576
                        G92 E0.0000
                        G1 E-4.0000 F2400
                        ; feature inner perimeter
                        G1 X142.700 Y142.700 F4800
                        G1 E0.0000 F2400
                        G92 E0.0000
                        G1 X157.300 Y142.700 E0.3442 F1125
                        G1 X157.300 Y157.300 E0.6883
                        G1 X142.700 Y157.300 E1.0325
                        G1 X142.700 Y142.700 E1.3767
                        G1 X142.100 Y142.100 F4800
                        G92 E0.0000
                        G1 X157.900 Y142.100 E0.3725 F1125
                        G1 X157.900 Y157.900 E0.7449
                        G1 X142.100 Y157.900 E1.1174
                        G1 X142.100 Y142.100 E1.4898
                        G1 X141.500 Y141.500 F4800
                        G92 E0.0000
                        G1 X158.500 Y141.500 E0.4007 F1125
                        G1 X158.500 Y158.500 E0.8015
                        G1 X141.500 Y158.500 E1.2022
                        G1 X141.500 Y141.500 E1.6030
                        G1 X140.900 Y140.900 F4800
                        G92 E0.0000
                        G1 X159.100 Y140.900 E0.4290 F1125
                        G1 X159.100 Y159.100 E0.8581
                        G1 X140.900 Y159.100 E1.2871
                        G1 X140.900 Y140.900 E1.7161
                        • Vetiundefined
                          Veti
                          cant see anything in the g code either.
                          try printing and when its happening pause the print and check the manual movement from the ui again.
                            drthomasw3
                            Ok I will do that
                            • botundefined
                              bot
                              Does your homing file(s) contain colons before the commands? The error message seems to show double colons.
                              Perhaps your z is not being homes before the print, because maybe your homeall file differs from the individual axes. This would result in the z axis only moving towards the z end stop, and not the other way (before homing). Is your z endstop located at min?
                              *not actually a robot
                                please upload your actual homing files rather than copy and paste.
