    BLTouch wont deploy but self test fine
    • GeorgeMundefined
      GeorgeM
      I have had my BLtouch working great for about 3 weeks now with my Duet 2 wifi. Today I upgraded the power supply to a 24v system and did a PID on the hotend and the bed.
      Now my BLtouch will not deploy during homing.
      As I say in the title it will deploy and retract during the self test, just no when homing.
      Here is the probe section of config.g
      M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
      M558 P9 H5 F120 A3 S.02 T7000 ; Set Z probe type to bltouch and the dive height + speeds
      G31 P500 X30 Y-10 Z1.39 ; Set Z probe trigger value, offset and trigger height
      M557 X15:285 Y10:275 P4 ; Define mesh grid
      Here is deplyprobe:
      ; deployprobe.g
      ; called to deploy a physical Z probe
      ; generated by RepRapFirmware Configuration Tool v2 on Wed Aug 14 2019 07:35:06 GMT-0600 (Mountain Daylight Time)
      M280 P3 S10 I1
      And retractprobe:
      ; retractprobe.g
      ; called to retract a physical Z probe
      M280 P3 S90 I1
      I'm stumped. Hope someone here can see something obvious that I am missing.
      • PaulHewundefined
        PaulHew
        When you say it will not home, is that using the homeall or homing z on its own?
        Your config.g looks right, not sure about the I1 in your deploy and retract.
        Please post homez and homeall files.
        P.
        RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
        Voron 2.4 disassembled..... Waiting for the RailCore Mini....
        • GeorgeMundefined
          GeorgeM
          Well I went back and retraced my wiring. Even though the connectors I have looked good, one of the pins had pulled out just enough to not make good contact. When I corrected that all is good again.
          Thanks
          • PaulHewundefined
            PaulHew
            👍 Good to hear
