    Solved End Stop Config
    • callielli
      callielli last edited by
      Hey legends,
      I have had some experience with Duet 2 Wifi boards and I am now attempting to install a new Duet 2 Wifi in a Cartesian printer I have at home.
      There is definitely someone basic I am missing but have been scratching my head for the last few hours, reading many posts with no clear answer.
      Please see my config attached.
      Have end stops (wired correctly SIG BLANK GND) and in the correct positions.
      Confirmed continuity test of end-stops, NO and when mechanically closed circuit is grounded to signal.
      Further confirmation as the LED on my Duet 2 board is blinking when circuit is closed during testing.
      The issue is, the signal is making no change on the printer, that is:
      Homing X, Y and Z axis' result in no movement as the firmware believes the end stops are triggered constantly.
      When using M574 X2 Y1 Z2 S0 I get the desired result (end stops show as No and then Yes when I close them)
      However this does not seem to save when I update the config.g file.
      I am new to the RepRap configuration so if someone could point out what I am missing, that would be awesome.
      Thanks in advance,
      Callum
      ; generated by RepRapFirmware Configuration Tool v2.0.0 on Mon Sep 02 2019 21:26:10 GMT+1000 (Australian Eastern Standard Time)
      M550 P"Little Boy" ; set printer name
      ; automatic saving on power loss is not configured
      M569 P4 S0 ; physical drive 4 goes backwards
      M584 X0 Y1 Z2 E3:4 ; set drive mapping
      M350Z16 I0 ; configure microstepping without interpolation
      M350X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation
      M92 X100.00 Y100.00 Z400.00 E415.00:415.00 ; set steps per mm
      M566 X720.00 Y600.00 Z12.00 E60.00:60.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X7200.00 Y7200.00 Z300.00 E3600.00:3600.00 ; set maximum speeds (mm/min)
      M201 X1000.00 Y1000.00 Z20.00 E2000.00:2000.00 ; set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1000 E1000:1000 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X255 Y255 Z350 S0 ; set axis maxima
      M574 X2 Y1 Z1 S0 ; set active low and disabled endstops
      M574 Z1 S1 ; set active high endstops
      M574 Z1 S3 ; set endstops controlled by motor stall detection
      M574 X2 Y1 Z1 S2 ; set endstops controlled by probe
      M558 P0 H10 F300 T6000 ; disable Z probe but set dive height, probe speed and travel speed
      M557 X15:215 Y15:195 S20 ; define mesh grid
      M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0
      M143 H0 S150 ; set temperature limit for heater 0 to 150C
      M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1
      M143 H1 S300 ; set temperature limit for heater 1 to 300C
      M305 P2 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 2
      M143 H2 S300 ; set temperature limit for heater 2 to 300C
      M106 P0 C"MAINBOARD_FAN" S1 I0 F500 H0 T18 ; set fan 0 name, value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P1 C"HEATBREAK_FAN" S1 I0 F500 H1:2 T100 ; set fan 1 name, value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 C"PART_FAN_E0" S1 I0 F500 H1:2 T45 ; set fan 2 name, value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 S"EXTRUDE_MAIN" D0 H1 F1 ; define tool 0
      M563 P1 S"EXTRUDE_SUB" D1 H2 F1 ; define tool 1
      G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets
      G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      T0 ; select first tool
      • T3P3Tony
        T3P3Tony administrators @callielli last edited by
        @callielli what is the output of M119 with the endstops untriggered and triggered
        www.duet3d.com
        • Veti
          Veti last edited by
          @callielli said in End Stop Config:
          Please clean this up.
          You need 1 line per different S parameter. And only the relevant x, y and z should be present.
          Something like
          M574 X1 Y1 S1 ; set active high endstops
          M574 Z1 S2 ; set endstops controlled by probe
          there is a space missing and the first line is not required
          B4138 is the default and most likely wrong for your printer. you will need to find the correct beta value for your thermistor
          callielli 1 Reply Last reply Reply Quote 1
          • callielli
            callielli @Veti last edited by
            @Veti thanks mate! That worked great! It definitely required some cleaning up.
            Appreciate your help.
