PART COOLING FANS
I have 2 blower type fans running on my part cooler. Should I make separate wire runs to the board, or can I gang them together and run one 2-wire lead to the board?
I have to 40x20 blowers "ganged" together - they don't draw that much current.
As long as the total current draw doesn't exceed the Duet rating and the voltage drop over the wires connecting the fans to the Duet is acceptable all should work fine.
