    Don't IP adress from pronterface for duetwifi
    986
    • maxxou
      maxxou last edited by
      i am blocked to point 11: not connected to the Duet WiFi web interface, no IP adress
      M552 S0
      SENDING:M552 S0
      WiFi server stopped
      M552 S1
      SENDING:M552 S1
      WiFi server starting up
      DuetWiFiServer version 1.03 (ch fork)
      Flash size 4194304, free RAM 32608 bytes, WiFi Vcc 3.07V, host name: duetwifi, reset reason: Turned on by main processor
      WiFi is running as an access point with name DuetWiFi
      help me
      i am french, and i am a wifi from a Box Freebox
      Thanks
        The Duet WiFi has failed to connect to your router. Maybe you didn't enter the password correctly. Go back to step 8.
        • maxxou
          Thanks dc42
          I tried several times my password and always nothing
          I tried a less complicated password with protection WPA and still no success
          Protection type wifi: WPA2-PSK/TKIP protocol EAPOL V2
          canal 11, bandwidth 20 MHz , 802.11n
          the IP adress duetwifi is 192.168.1.100 when is connected, my DHCP range 192.168.0.100 to 192.168.0.140
            Are there any accented characters in the password? There have been reports of problems when the password contains non-ASCII characters.
            • maxxou
              no, there is one circumflex accent in my password
              but i already tried with one password more simple and no success
              I do not understand why the duetwifi does not connect to my wifi
              • Mike
                Mike last edited by
                It's not only accented characters, my Duet would not connect until I removed + and = from the Wi-Fi password.
                • maxxou
                  ok thanks Mike
                  i try with a new pasword
                  • maxxou
                    Eureka
                    it works
                    great thanks Mike and dc42
                    • maxxou
                      What are really the characters accepted by duetwifi? It's not very clear on the wiki
                      What is the maximum length of the password?
                      thanks
                        The current firmware uses library code that I didn't write, so I don't know exactly which characters are allowed; but I can't see why characters like + and = shouldn't work because the code appears to decode them correctly. Maximum password length is currently 63 characters.
                        This issue will be resolved in the new WiFi firmware that I have started writing, assuming that the bug doesn't lie in the ESP8266 SDK code.
                        • maxxou
                          ok thanks dc42
                          the forum is a great tool for everyone
