    X y motor confusion
    • minsk
      minsk last edited by
      so have x and y wired up on my large format printer im building.
      when i click to move x 100 mm y moves also…
      hmmm
      when i click y to move 100 mm x moves also
      they are of course wired seperately..all go in to there respective ports on the wifi board etc.
      EDIT: ok weird…z is not hooked up and if i click z on the screen x and y move also
      any ideas would be a appreciated
        It sounds to me that you are using a config.g file that is meant for a delta printer. Use https://configurator.reprapfirmware.org/ to generate new config.g and homing files.
        • minsk
          oh snap…i think you are right 🙂
          • minsk
            mmmk..
            so i have a diff kinda build.
            im using 4 motors
            18x18 square.
            i have is kinda set up as an xy i guess..but not really 😛
            i have one motor on x…one motor on y.... 2 motors on zed
            2 motors on z because it will be lifting an 18 inch bed
            my question is how do i hook the two z motors up to the duet wifi
            i did a new config file on reprap and did the cartisean.
            now the axis are working properly on ax and y
            moving individually
            on to drilling holes in my 20x20 bed...this should be fun
              See https://duet3d.com/wiki/Connecting_stepper_motors.
              • minsk
                ahhh…got it...thank you sir 🙂
                wiring up my end stops now 🙂
