    For those with multiple z steppers...
    My Duet controlled machine
    • fcwiltundefined
      fcwilt
      For those with multiple z axis steppers that are using them for bed leveling how are you connecting the lead screw to the bed?
      I assume I need to allow for some amount of movement in the connection.
      Thanks.
      • JamesMundefined
        JamesM
        Here is a good article about kinematic bed mounts.
        https://drmrehorst.blogspot.com/2017/07/ultra-megamax-dominator-3d-printer-bed.html
          Take a look at the railcore 2 design. They have some flex built into the bed lead screw mount points. Without some play you get binding as you surmised.
