extruder motor didn't work
Hello
Extruder Motor doesn't work, when i like to extrude. Hotend is on 200 degres.
I changed the motor and he still doesn't work.
Is there a fault in the config?
In the test config mode he works fine.best regards
goodchrhereConfig are below:
; Configuration file for Duet WiFi (firmware version 2.xx)
; generated by RepRapFirmware Configuration Tool v2.0.3 on Sat Sep 07 2019 20:36:27 GMT+0200 (Mitteleuropäische Sommerzeit); General preferences
M550 P"Cinemucker" ; set printer name; Network
M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M92 X160.00 Y160.00 Z4266.67 E458.81 ; set steps per mm
M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
M906 X1500 Y1500 Z1500 E1500 ; set motor currents (mA)
M84 S0 ; Disable motor idle current reduction; Axis Limits
M208 X300 Y400 Z400 S0 ; set axis maxima; Endstops
M574 X1 Y1 Z1 S0 ; set active high endstops; Heaters
M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0
M305 P1 T100000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 1
M143 H1 S300 ; set temperature limit for heater 1 to 300C; Fans
M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off; Tools
M563 P0 H1 F0 ; define tool 0
M501 ; load saved parameters from non-volatile memory -
Config looks ok. Are you sure you're connected to the right extruder driver?
i have connected to extruder 0
Your tool definition is missing a drive assignment
should be instead
https://duet3d.dozuki.com/Wiki/Gcode#Section_M563_Define_or_remove_a_tool
