    No current on showing on DWC
    • Whitestsandundefined
      Whitestsand
      I have been installing a Duet2 wifi to my corexy and im having a problem getting the motors to behave correctly. If I try to home x or y the motors will turn slowly. Using G1 S2 gcode to move motors without homing I cannot get the motors to move. I have tried to lower and raise the voltage with no success. In the DWC the current is showing 0 mA. ????alt text![alt text](image url)
      I have included and portion of the config.g showing my network. Everytime I have to restart the network with M522 S1. It doesn't seem to be using the line in config.g.....alt textalt text
      Whitestsandundefined 1 Reply Last reply Reply Quote 0
        Whitestsand @Whitestsand
        0_1567893402217_2019-09-07.png 0_1567893431564_2019-09-07 (3).png 0_1567893442601_2019-09-07 (2).png 0_1567893450533_2019-09-07 (1).png
          Whitestsand
            You must change your M911 command to use double quotes " instead of single quotes '
            That line is preventing the rest of your config from being read.
            There was a bug in the web configurator that mistakenly used the single quotes. If you've recently used the web configurator to get your config set you may have been affected. The problem has now been fixed, though you may have to clear your cache and force a reload of the configurator page.
              Whitestsand @Phaedrux
              @phaedrux Thank you very much.... worked like a charm.
