    Could use some feedback on a DSF packaging pull request
    DSF Development
    • gtj0undefined
      gtj0
      If anyone's hacking on the DSF, I could use some feedback on a pull request that refactors the packaging stuff.
      https://github.com/chrishamm/DuetSoftwareFramework/pull/62
      I'm guessing @chrishamm is pretty busy at the moment and might not get to it for a while.
      gtjoseph opened this pull request in chrishamm/DuetSoftwareFramework
      closed Refactor packaging scripts #62
      • T3P3Tonyundefined
        T3P3Tony administrators @gtj0
        @gtj0 apologies for not sorting out a category until now, hence moving the post into here.
        I hope @chrishamm will have a chance to look at it soon. I don't have any specific comments, other than its large amount of additions/changes in one pull request which makes it more difficult to merge.
        www.duet3d.com
        • chrishammundefined
          chrishamm administrators
          This is looking great - I will check it out and merge it very soon. You could remove the dpkg-scanpackages part though, because that part has already been automated on the server side.
          Duet software engineer
          • gtj0undefined
            gtj0
            @T3P3Tony No worries!
            @chrishamm Cool, I'll remove the scanpkgs then I'll do a separate commit/pull request for the rpm support.
            • gtj0undefined
              gtj0
              @wilriker When you build for Arch, how are you treating the dwc "2.0.0-2" version string since the dash makes it an illegal 'Version"?
              • wilrikerundefined
                wilriker @gtj0
                @gtj0 Yeah, that's a special case where I rewrite the version completely to what the actual DWC version is. In the current stable package that's 2.0.0.RC8.b3. The unstable package (not published in AUR) has b4.
                EDIT: also the -2 means second repack/release of version 2.0.0so this is not really part of the version. At least for Arch Linux PKGBUILD files this will be controlled by a separate variable pkgrel.
                Manuel
                My Tool Collection
                • gtj0undefined
                  gtj0
                  Gotcha, thanks! Yeah that's what I did with the -2. I made it part of the Release rather than Version.
