Thinking of adding a auto bed leveling sensor.
441
  • undefined
    CarlBosson
    I am running a Folger Tech FT5 R2 with the duet wifi control board and Pt-100 sister board, Titan aqua extruder, and factory supplied 24VDC power supply. I am currently printing on a glass bed. We do have an inclosuer and sometimes run PEKK. The temp inside the inclosure is normally around 75-80 Deg C.
    I am thinking of adding an auto bed leveling sensor and wanted some input. Do you have any sugestions?
    There is no box!
    • undefined
      Danal
      just me... the only two sensors I've ever made work "totally trouble free" are an Inductive above a steel bed and a Smart Effector on a Delta. I realize neither of those will work for you... but... do you have a metal layer below the glass? Alu heat spreader? Inductive just might work fine. Worth a try, imho.
      • undefined
        CarlBosson
        Its an Aluminum bed under the glass
        There is no box!
          A Former User
          I regularly run an one of David's IR sensors up to 80C with no problems.
          undefined 1 Reply Last reply 13 Sept 2019, 13:17 Reply Quote 0
          • undefined
            Danal
            IR or Inductive should work. Of course, that's technically leveling the layer below the glass... but the glass should be consistent enough that that's OK.
            • undefined
              CarlBosson @A Former User
              @CaLviNx Where do I get one of "Dave's IR Sensors"? Thank you
              Carl
              There is no box!
              undefined 1 Reply Last reply 13 Sept 2019, 13:41 Reply Quote 0
              • undefined
                Dougal1957 @CarlBosson
                @CarlBosson from the Duet Shop abovelink text
                • undefined
                  Bear in mind that the IR sensor does not work well with glass beds if they are coated with glue stick, hairspray etc. It works reasonable well on clean uncoated glass that has a matt black surface underneath it. You can put a sheet of black paper between the bed and the glass, or spray paint the aluminium with matt black barbecue paint and cure it at a suitable temperature.
                  ? 1 Reply Last reply 13 Sept 2019, 21:52 Reply Quote 0
                    A Former User @dc42
                    @dc42 said in Thinking of adding a auto bed leveling sensor.:
                    Now that's very odd because I use various types of glass and ceramic bed surfaces in conjunction with printafix and have no issues with the IR sensor getting a reading
                    3 out of 9
