Connection lost by M203 setting .
  • Connection lost by M203 setting ?
    Firmware Electronics: Duet Ethernet 1.02 or later
    Firmware Version: 2.04RC1 (2019-07-14b1)
    Web Interface Version: 1.22.6
    CoreXY, double Z steppers with high gear ratio (1:100)
    During my Z axis testing of the machine... I experienced my first "Connection lost" of the web interface.
    This one was not generated by switching of the board power, but by a "change" in the M203 Z-setting in the config.g
    For my board and network setup, it's reproducable.
    Maybe there is a simple explanation for this.. or just a setting;
    @wydowaw generally the Duet 3 maxes out at 130Ksteps/s/axis when multiple axis are being moved at once. For your Z axis that should be ~2900mm/min. Saying that, in this test maybe you were only moving the Z axis?
    Also intresting that You had connection lost at 1000mm/min on the second time but not on the first.
  • Correct I am only moving the z-axis (Za,Zb)
    My M92 max value is 2640 , close to ~2900
    But why is this reason to lose connection on the network card??
    Maybe my first test at 1000 was a short time span and it homed..., and I didn't spot the connection loss.
    first you lose the speed indication ...which is followed by the connection lose.
    130Ksteps/s/axis...that's intresting,
    just posted a problem how to do 20Ksteps/axis......so that should be possible! But How??
    @wydowaw My understanding is when you get >130Ks/s the MCU does not have enough time to do lower priorty tasks like the web server.
  • @T3P3Tony
    OK thanks ,
    Case Solved !!
