    Duet Bed Mesh Compensation incorrectly showing Z Offset ?
    • simonboydfoleyundefined
      simonboydfoley
      Hi All,
      I have a BLTouch Z Probe with my Duet2Wifi for my CR10s printer.
      I upgraded to the latest firmware, web server etc and I now get the following error when ever I do a mesh bed compensation;
      G29
      Warning: the height map has a substantial Z offset. Suggest use Z-probe to establish Z=0 datum, then re-probe the mesh.
      49 points probed, min error -1.482, max error -1.175, mean -1.340, deviation 0.077
      This is the procedure I normally follow.
      (With Z offset set 0 G31 X-40 Y-10 Z0 P25 I1).
      1. Home all axis.
      2. disable axis limits. (M564 S0, G1 Z0)
      3. level the nozzle to the bed and set actual Z (G92 Z0)
      4. Work out the actual Z offset needed for the probe (G1 Z10,G30 S-1) x 5
      5. work out the average offset and then set the offset in config.g
        G31 X-40 Y-10 Z*** P25 I1 where *** = my calculated offset (positive decimal)
        6). restart the Duet.
        7). home and center.
        8). Run Bed mesh compensation
      I get the following graph from the Duet and the error message!
      So it shows the bed as being "below Z=0"
      so it looks like the duet is mistakenly applying the offset twice ??!?
      It dose not seem to be affecting the print so it could just be an error in the software ?
      If I do a mesh compensation after setting the Z to the actual Bed I get a more reasonable result ....
        Can you post your config.g and homing files so we can see what is being applied and when?
        Have you seen this? https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation
          simonboydfoley
          hi @Phaedrux , Thanks for the reply
          to answer your questions, No I will read it now .... not sure it existed at the time I bought my Duet. I'll see if I have done something dumb.
          [Edit: The only thing I have spotted that I don't do is cancel previous mesh bed levelling before I set the Z=0 and offset procedures, cant see that being relevant as the G92 z0 when the nozzle is on the bed sets the golden reference point ]
          ... I attach requested files
          homeall.g
          homedelta.g
          homex.g
          homey.g
          homez.g
          heightmap.csv
          config.g
          • Vetiundefined
            Veti
            your home scripts need updating.
            z=0 should be determined by the G30 command.
            and you will need to create deploy and retractprobe scripts
            examples from the configurator
            ; homeall.g
            ; called to home all axes
            ; generated by RepRapFirmware Configuration Tool v2.0.4 on Sun Sep 15 2019 21:01:39 GMT+0200 (Central European Summer Time)
            G91 ; relative positioning
            G1 S1 X-235 Y-215 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
            G1 X5 Y5 F6000 ; go back a few mm
            G1 S1 X-235 Y-215 F360 ; move slowly to X and Y axis endstops once more (second pass)
            G90 ; absolute positioning
            G1 X15 Y15 F6000 ; go to first bed probe point and home Z
            ;G91 ; relative positioning
            ;G1 S2 Z5 F100 ; lift Z relative to current position
            ;G90 ; absolute positioning
            for the deployprobe see
            https://betrue3d.dk/bltouch-on-duet-wifi-configuratio-and-usage/#deployretract
            • Vetiundefined
              Veti
              @chrishamm the configurator does not create the deploy and retract scripts at the moment.
