    Replace the Wifi or Ethernet module by the ESP-13?
    1.5k
    • A Former User?
      A Former User
      You can upload the DuetWifiServer firmware to the SD card and flash it from the serial(usb) console, so thats not a problem if 2MB flash is enough. I've only previously seen dc42 reccomending using ESP-07S for external antenna, and that is the 4MB version of ESP-07 but not sure if 4MB is a requirement.
      • A Former User?
        A Former User
        dc42 said in swapping out ESP module for ethernet module:
        imrj said in swapping out ESP module for ethernet module:
        dc42 ok dc...yea i got one of those too with an external antenna....i can swap it out but do i need to worry about flashing anything into the ESP07S?
        You will need to copy DuetWiFiServer.bin into /sys on the SD card if it isn't already there. Then send M997 S1 from USB or PanelDue to install it on the new module.
        Make sure it is the ESP-07S that you have. The older ESP-07 won't work.
        Kanyoundefined 1 Reply Last reply Reply Quote 0
        • Kanyoundefined
          Kanyo @A Former User
          @bearer
          The original ESP8266 wifiserver doesn't seem to work well with 2MB flash..
          (https://github.com/dc42/DuetWiFiServer >> https://reprap.org/forum/read.php?2,582444,582444#msg-582444)
          and ESP-07 has only 1MB flash, but ESP-07S seems to have 4MB
          ESP-WROOM-02 with 2MB flash may not be good idea 😞
          At least,it looks physically possible without magical smoke or some thing, thanks to the powerful onboard flash of the reprap firmware.
          thanks for infomation.
          • A Former User?
            A Former User
            Yeah, flash size was the primary concern.
            You could perhaps get the Ethernet version and use a Raspberry Pi as a wireless bridge now, and at some point you could be able to remove the Ethernet and connect the Pi to the Duet 2 Ethernet in the same way as the Duet 3 if/when such a firmware is made for the Duet 2.
            (Asuming you can use the Raspberry Pi or similar single board computer)
            • Danalundefined
              Danal
              I wouldn't mess with the board. I'd get an ethernet Duet, and plug a Japan certified device with a cable a few centimeters long. There are a ton of devices out there specifically designed for the task of making an Ether client look like a Wireless client.
              You do NOT want a Bridge or AP... it is Ok if it has those "modes"... you want a device that is (or set to the mode of) being a client.
              • Kanyoundefined
                @bearer
                Wow Duet 3? You say remove the ethernet module and connect the Pi to duet board directly?
                • A Former User?
                  A Former User @Kanyo
                  @Kanyo said in Replace the Wifi or Ethernet module by the ESP-13?:
                  ref this thread and this reply from dc42 https://forum.duet3d.com/post/106138
                  • Kanyoundefined
                    Kanyo @Danal
                    @Danal
                    before posting here I was thinking about plug a Wifi Bridge.
                    A device acting as a client may different from a bridge or AP,I have never seen such a thing
                    For example, what kind products can be used?
                    • A Former User?
                      A Former User
                      Technically it should be both a wifi client and then a bridge between the wifi client and the ethernet port, which is how it would be done with a board like a Raspberry pi.
                      Kanyoundefined 1 Reply Last reply Reply Quote 1
                      • Kanyoundefined
                        Yeah I know, such like WRH-583BK2-S
                        or as you said RPi can bridge between the wifi client and the ethernet port, right?
                        I just wondering what kind of network device can just being the client Instead of connected ethernet ,not bridge or AP.
                        • A Former User?
                          A Former User
                          Admittedly I haven't tried it with the RPi since way back when Wifi was a USB stick, and being able to run as an actual bridged connection may depend on the WiFi chipset in use; but in any case it should be possible to do a routed connection and forward the necessary ports.
                          (I'll see if I can find time later this week to borrow the Duet 3's RPi 3B and try bridging it to the Duet 2 Maestro, but busy week)
                            dc42 administrators @A Former User
                            @bearer said in Replace the Wifi or Ethernet module by the ESP-13?:
                            Originally the web pages were held in flash memory on the ESP module, which is why there was a DuetWiFiServer.bin file and you needed 4Mb flash memory. Now that the web page files are served from SD card, even 1Mb ought to be enough. But I've never tried uploading DuetWiFiServer to a module with less than 4Mb of flash.
                            The reason we specify the ESP-07S not the ESP-07 is that only the S version has been FCC certified.
                            The WROOM module is slightly wider than the ESP-12S. We looked at it a while back before the ESP-07S became available, and we concluded that it didn't quite fit in the space available.
                            • Danalundefined
                              Danal
                              Probably my odd phrasing.
                              It is quite fair to say that what you need is a device acting as both a client and a bridge to the Ether. My real point was: Not an AP.
                              And... WRH-583BK2-S is an example of what you DON'T want. This device 'expects' internet on an Ether port, and routes it to a WiFi segment where this device is the AP for that segment. That is the "wrong direction" for what you are trying to accomplish.
                              • Danalundefined
                                Danal
                                And... to my best reading of a translation of the user manual for the WRH-583BK2-S, it looks like it actually WILL do what you need.
                                See "child machine mode" on page 47 of the full manual here
                                • Kanyoundefined
                                  Kanyo @dc42
                                  @dc42 So that's it.
                                  Thanks for the great effort, may be try to make a breakout board someday.
                                  I feel sad that WROOM module was not chosen, no help for a larger footprint.
                                  The big reason I want to replace a Wifi module is mDNS protocol.
                                  Are there any plans to implement the mDNS protocol on the Duet2Ethernet?
                                  Danalundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                  • Kanyoundefined
                                    Kanyo @Danal
                                    @Danal
                                    Sorry for the confusion on the Japanese page, thanks for looking seriously.
                                    May be this picture is a good explanation of what this device can do.
                                    Danalundefined 1 Reply Last reply Reply Quote 0
                                    • Danalundefined
                                      Danal @Kanyo
                                      @Danal
                                      Yep, looks like it WILL do it. Nifty little gadget.
                                      • Danalundefined
                                        Danal @Kanyo
                                        That's a pretty good reason to make the "WiFi Client to Ether" box a Raspberry Pi. Setting it up as the client/bridge is straightforward (tons of examples) and mDNS is also relatively easy. Being *nix literate at the command line is helpful, but not essential, due to the many examples.
                                          dc42 administrators @Kanyo
                                          When we designed the Duet WiFi, there was only one WROOM module and no external antenna option; whereas there were several ESP modules, some of which were certified. Since that time there have been two new WROOM modules, both certified, one with external antenna. To change to it would have required moving the SD card slot, which would have been incompatible with existing enclosure designs, and would in turn have required moving the mounting point for the Ethernet daughter board - so a new version of the daughter board would have been needed.
                                          Yes.
                                          • Kanyoundefined
                                            Kanyo
                                            I expect so much.
