    heater fault
    • ander
      ander last edited by
      Hi there!
      i was very happy printing many stuff with my duet based printer and suddenly without any change being made it is giving me heater fault.
      The weird thing is that if i put the temp. manually it does work fine, but when printing mode, while doing autolevel the parameters goes up a lot and down too, so i cannot print because after autolevel says heater fault.
      Also, if the autolevel is performed without errors the print goes fine.....i just changed the temp sensor and it is still doing the same. what can i check?
      Thanks
      • Monster Delta
        Monster Delta last edited by
        Are you using the smart effector
        • ander
          No well, it is a custom made effector, the noozle touches the bed and trigers a switch for autolevel function.
          I realized i didn´t explain very well,i ment the temp goes up and down like crazy, i mean it goes from 230 to 210 in a second and back up in the following second, is not a natural temp fluctuation.
          • Veti
            Veti last edited by
            did you do the autotuning with all fans on?
            • ander
              Hi there!!
              It looks like it was some issue in the wiring, altho looks in good shape, i changed the wire and it looks like it runs fine so far.
              Thanks
