    Dudes about Steinhart-Hart Equation
    594
    • peirof
      peirof last edited by
      i d'like draw the funtion of Steinhart–Hart equation, for know how affects the pairs of T1/R1, T2/R2 and T3/R3, that are mi entrance dates, but i have two doubts.
      The Equation from Wiki, and others webs, seems these:
      From Wikipedia
      The Steinhart–Hart equation is a model of the resistance of a semiconductor at different temperatures. The equation is:
      T is the temperature (in kelvins),
      R is the resistance at T (in ohms),
      A, B, and C are the Steinhart–Hart coefficients, which vary depending on the type and model of thermistor and the temperature range of interest
      Dude 1: What are the values of R (the resistance in ohms), R(in middle) is the resistance of thermistor when temperature its B? and R(in final) is the resistance of thermistor when temperature its C?
      Dude 2: m305, can use C parameter ( the Steinhart-Hart C coefficient, default 0), but i can't see this variable in formula. Where its used?
      Thanks
      Danal 1 Reply Last reply Reply Quote 0
      • Danal
        Danal @peirof last edited by
        @peirof said in Dudes about Steinhart-Hart Equation:
        I am going to attempt to directly answer your questions; at the same time, the way you've phrased the questions indicates a basic misunderstanding of how equations work. I suggest you talk to a math teacher about the equation. That teacher does not have to know anything about thermistors or such. They just need to explain to you that "A" "B" and "C" only change when a different thermistor is used... therefore, the only two things that can change are T and R. Changing T changes R. And that's it.
        Get someone to discuss equations with you. Only then will any of this make any sense.
        In the above equation, "T" is the temperature; "R", resistance in ohms, will have the same value both of the places it occurs. "R" will only change when the temperature changes (or a different thermistor is used, which will have different "A", "B", and "C" coefficients)
        • nhof
          nhof last edited by
          What are you actually trying to do? Program a thermistor accurately into the duet or something else?
          If you are trying to get a thermistor model from measurements you have taken for T1/R1, T2,R2, and T3,R3, you can't use the equation as is. You should use a calculator like this one: https://www.thinksrs.com/downloads/programs/therm calc/ntccalibrator/ntccalculator.html. Put your temperatures in to get the A, B, C coefficients which you can then plug into the formula you posted.
          Formula is used when you already know the A,B, C coefficients and resistance R to calculate the temperature T. For most therms R and T have an inverse relationship (Most therms are NTC which means negative temperature coefficient).
          You might also use the words "Question" and "Questions" instead of "Dude" and "Dudes". "Question" is the correct word, it will make it easier for others to understand 🙂
          • peirof
            The idea its draw in Excel ot similar the Stein hart función.... For what:
            • i have used the web, but after put the temperature /resistance pair and obtain a B for put in Duet. When Duet hoy the nozzle, the temperature measured its 20 degrees, aprox, far of the Duet showed temp....
            • i d like see the effect of change B, in the curve. Maybe, of o can see the responde graph change, with a rapid feedback... Can fine tuning B value.
            • For adjust the M305, in this momentos, i do triying. Change B value, heat nozzle to working temperature, and see how near or far its from Real temperature
            • know my math skills are límited, like English... and I apologize for it
            Thanks for help
            • Danal
              • peirof
                R in general formula, its the resistance at ambient temperature... Not its the same R of coeficients... No?
                • nophead
                  nophead last edited by
                  R in the equation is the resistance of the thermistor at temperature T, they are the variables. A, B, C are constants for a given thermistor.
                  When T is 25C then R will be the thermistor's nominal resistance, e.g. 100K.
                    The B value entered in M305 or M308 is the reciprocal of the B coefficient in the S-H equation. This is because when C is zero, it's the Beta value in the thermistor beta model.
                    • peirof
                      after some reading, i think have a method for obtain Beta, for unknow termistors.
                      i have do a spreadsheet with the system...
                      I have do some test, and seems works.
                      Still to be done
                      • Draw the graph
                      • Calculate the value of C, for M305
                      Could someone please review it, to tell me what mistakes it has?
                      Calculate Beta for the thermistor.xls
                      Thank you
