    arm64 packages
    DSF Development
    • gtj0undefined
      gtj0
      @chrishamm Can you start building and publishing arm64 debs and seeing as someone mentioned in an interview with Tom Sanladerer that the Jetson Nano was supported. 🙂
      T3P3Tonyundefined 1 Reply Last reply Reply Quote 1
      • T3P3Tonyundefined
        T3P3Tony administrators @gtj0
        @gtj0 not officially supported yet but it's a goal. Thanks for all your work in proving it works. I guess @chrishamm needs a nano!
        www.duet3d.com
        • gtj0undefined
          gtj0
          Don't forget, you can run a Pi3/4 in 64 bit mode. 🙂 I'm not suggesting that you produce a distro for 64 bit but the packages would be nice especially since the DSF build process can do it now.
          • chrishammundefined
            chrishamm administrators
            Sure, I can create two new feeds for that - thanks to your new build script it should be fairly easy to provide them 😉
            Duet software engineer
